It's all good just make the resulting space up with old bits of newspaper and filler - perfectly acceptable
Its stronger than rust isn't it!
You utter cowboy:nono: Everybody knows that to effect a permanent and structurally sound repair you should use a wire mesh and fibreglass mix under the filler. Have you never read the instructions on an Isopon packet!It's all good just make the resulting space up with old bits of newspaper and filler - perfectly acceptable
good time to start welding John
The Daihatsu Cuore Turbo had a four cylinder 660cc engine and is about four inches wider and six inches taller than the Vivio. The Justy was huge in comparison. I'll see if I can find the photo's of mine when I get home.
Now in Minehead; and with a different seller. Appears to be £495 BIN... -- possibly....
