Is anyone in desperate need of these? If you are, speak now & I'll not bid it up.
If not, I'm planning to bid until they go silly. I want one or two as spare/s in case any of mine go missing - I keep expecting to lose one!
If anyone here is in a similar position please make yourself known. I don't want to be bidding against another member who also wants a spare when we can just divide them up between 2/3 of us for a lower price!
Did that make sense?
Where did your ones go? Were there none on it when it arrived?? I'm fairly sure there were 2 on it? Definitely not 4 but there never were.
If Vernon doesn't need the standard centre caps I have spare, you can have them if you want?
Only one of your Sisleys needs these, early ones had standard ones.I need a full set and i have just been outbid
Out of 2 sisley i have none!
I though that the 88 sisley would have these?
This seller is the guy that sold me the 89 sisley so the must be from that one for sure
In theory you need to loosen the bolts. In practice if you're not worried about damaging them (or any of the bolts are loose) they can sometimes be pulled off.
Once it is free from 1 bolt it can definitely be pulled off easily as I've done that in the past (carefully) to save time.
Yes I thought there were 2. Was one where the strap has been put on the n/s? I was talking to the 2nd bloke (what did you call them - reminds me of a film was it Wrong Turn ?) on the n/s front at the time so no idea what was happening that side.
