Coupe Cheap Coupe
Coupe Cheap Coupe
Can't tell much from photographs. Could be needing all number of things, belts for instance & that aint cheap. Brakes & suspension may need doing. If anything engine wise is not right well..how deep are your pockets.
Obviously you need to view the car. Even if you're handy with spanners the Coop is not the easiest of cars to work on. Even doing an oil & filter change is quite a fanny about. Any Coop owner will tell you that.
