1368cc 16v enigne!!!!!!
hell no :D :p
I haven't fitted mine yet, it will be a few months, but its def not going anywhere. Just found it when browsing eBay.
Mine is from a panda, but thats a stilo....no difference really.
I has no alternator in the pic (can't use it anyway, need a sei or punto one), the air con pump is gone.....not worth anything, couldn't sell mine on ebay.
More miles than mine and a bit more ££ but still these are highly sought after so thought it worth posting (y)
Kristian
hell no :D :p
Kristian
Ah Gdgd,
i've posted a couple of these up but as far as i'm aware no-one off heres bought one apart from Aaron/Emma
Jordan
interesting....you have that aircon pump bracket and the non movable alternator with an auxilery belt tensioner? and a bracket that bolts onto wher ethe engine mount needs to go?
when i said cinq/sei/punto, I simply meant that style alternator that is used on some other models.
Kristian
So outta interest....
These stilo engines are the ones that have the clutch that fits a cento as is fitted to some of the turbos right? does that mean the panda 100bhp has the same clutch? Just wondering as i'm in tge market for such a clutch at the moment..
Oh and Jamie, no contest, engine lol
use the punto mk1 inlet, tb and fuel rail, and it is returnable as standard. So you don't need to do anything other than plump it in (y) Go on, you know you want to :devil:
Give them a rinig, I'm sure there is some movement on that price :D
Kristian
I was wondering when someone would spot this, its been on there for weeks. I would be tempted but with the amount of internal mods and performance I am getting will stick to 1242 16v for time being.
If I wanted to go nuts and turbo it, would wait for 1368 t-jet engine! As the block is sufficiently strong from the factory to cope with the extra loads placed by a turbo and will feature a low comp set up at a guess.
In the right form should make 150bhp in a cento, which would be pretty insane. I think if you placed that kind of power in the n/a 1368 it would be time to go boom boom without mega ££££!
How much do you think a complete 120 or 150 turbo engine would cost though, and how rare they would be?!
The main engine (block, head, valves, cams etc) is £3700 from fiat!
The 1368 turbo's (120 and 150) both share the same piston though (y) and are about £80 each. Probably better to go with aftermarket pistons though, and they could match the non turbo block possibly better.
I think even 120/130bhp turbo would be more than enouh in these cars as they are so light, and i pitty the poor gb mount :D :devil:
