FIAT Auto Specialist Team
Thread Tools
Old 05-04-2014   #1
Daylight Running Bulbs
Does the parking lights use the same bulb as the Daylight Running Bulbs.
Thunderbug is offline Reply With Quote Quote
Old 10-04-2014   #2
Re: Daylight Running Bulbs
No mate, DRL are w21w and side lights are w5w/501
Lloyderzz is offline Reply With Quote Quote
Old 11-04-2014   #3
Thanks for the info, I've bought some LED's off Ebay for £5.
Old 11-04-2014   #4
Switzerland
If they work without the warning on dashbord, thanks to keep us informed
Punto 2012 Easy - 1.4 8V 77CV - Blue
Mkala is offline Reply With Quote Quote
Old 12-04-2014   #5
Today i've changed to LED Daylight Running Lights but on the drivers side, 2 of the lights keep flashing, when the car is locked and engine off.
Is this a MOT failure & can the DRL dash error be turned off via a garage software when hooked up to the car.
Old 12-04-2014   #6
These are the ones I bought for DRL's mate, no errors and look the part.
Old 12-04-2014   #7
Picture doesn't do the bulbs justice, there much whiter in real life.
Old 13-04-2014   #8
Switzerland
Quote Originally Posted by Lloyderzz View Post
Thank you for the info, they look great, but they are not LED.
Old 13-04-2014   #9
Quote Originally Posted by Mkala View Post
I understand that, but there a better option than having errors on the dash constantly.
Old 13-04-2014   #10
I've done some research and found out a set of cambus free T20 W21W 7440 LED's with built in resistors works:
I've ordered a set of these, keep you updated:
Old 13-04-2014   #11
Switzerland
I agree, if it is not possible to have error free LED, it will be my choice.
Quote Originally Posted by Thunderbug View Post
Thanks in advance, I hope they will work error free
Old 15-04-2014   #12
Here's part 1 of the DRL bulb change, If the LED's i've bought don't work i'll stick with these as they are white / bright enough & will pass the MOT.
Old 16-04-2014   #13
What ones are they in the pic mate?
Old 30-07-2015   #14
Like Lloyderzz I ordered the MTEC 380 W21W Super White Xenon Effect Bulbs 7440 “Pair” from hids-direct on eBay.
The ones they sent are NOT the same as those in their eBay picture - they have a black plastic extension on them which pushes the bulb and therefore the filament further into the reflector. So the filament is not at the focus of the reflector and the result is hopeless!
The original fit W21W bulbs are glass-only wedges but are nearly yellow by comparison! ATM I'm running one of each (!); one of the MTEC ones supplied by hids-direct failed after only 4 days use ... b*st*rds.
Can't find an LED replacement that's CANBUS compatible, yet!
Keep us informed please!
C6UPE is offline Reply With Quote Quote
Old 30-07-2015   #15
Quote Originally Posted by C6UPE View Post
I had a set of mtec ones last year which were glass only wedges. Earlier this year one bulb failed so hids direct replaced with the plastic version. They didnt seem to fit in the bulb holder as well as the glass version and stick out more. After a couple of months one of these failed. Im now back using the standard bulbs.:banghead:
ITS A FIAT THING
stevie4117 is offline Reply With Quote Quote
Thread Tools
(T) How do you get the daylight running bulbs out ?? AdynGill 500 45 20-08-2017 22:48
(G) Daylight Running Lights PiersCM Sedici 15 25-11-2013 11:55
(T) daylight running lights red diesel Qubo 23 18-04-2013 21:38
(G) Daylight running bulbs Franda 500 5 10-02-2012 09:57
(T) Help with Daylight Running Lights Booth Grande Punto 1 13-09-2010 21:00
