If you mean the latter then Brakes, Engine Map, Air filter, Wheels, Suspension and Exhaust. Total power is up to 180 just like the old Grande EsseEsse but with the more economical MultiAir engine.
You know the rev limiter isn't the same as the red line don't you? And you'd need to be stuck on the engine screaming for its life for just over a minute not a second or two.
The engine screams at you its a way passed the red line and normally happens if you completely forget to change gear or shift into a lower gear at high speeds. Unless its changed for the evo the time limit was 1 minute which is actually a fair amount of time. Looks like the SS kit is back on the cards
