Technical Error p1305 neutral signal learn
Liakaros
PLEASE HELP....i have alfa romwo mito 1.4 170 hp and i have p1305 neutral signal error and check engine... I changed the clutch sensor and the transmission sensor and it still didn't go off...thanks a lot ?
You may need to us a diagnostic machine to turn it off
You may need to go through a setting process using a diagnostic machine.
Not just a code reader eraser.
You may need to undo what you have done and put it back to how it was when it was built at factory
if you have already replaced the clutch sensor and transmission sensor but the P1305 error code persists, I recommend checking the wiring for any damage or loose connections
