im Axle Specialists
Old 03-11-2019   #1
GP TJET p0240 HELP PLEASE!!
Getting 'p0240 boost pressure sensor B circuit' fault code, cars very down on power and only making 3psi of boost. Checked all the vac lines on the boost solenoid and they all seem good and the right way round, any other ideas? Tia.Click image for larger version
mwilde992 is offline Reply With Quote Quote
Old 03-11-2019   #2
nikrox has donated!
Re: GP TJET p0240 HELP PLEASE!!
and is the boost solenoid itself working?
nikrox is offline Reply With Quote Quote
Old 03-11-2019   #3
Quote Originally Posted by nikrox View Post
How can I test it mate?
Old 04-11-2019   #4
Fixed it turns out its recirc valve opening at 3psi blocked it up and back up at 1bar
Old 04-11-2019   #5
varesecrazy has donated!
Good news
You mean the recirc. Opening was letting the pressure out.
So a ' leak' stopping the pressure building.
How did you stop this?
Charlie
Old 04-11-2019   #6
Quote Originally Posted by varesecrazy View Post
Good news
Charlie
Read up online that the recirc can be faulty and leak air/open to early before hitting peak boost so I blocked off the recirc then took it for a test drive and was back up at 1bar of boost running perfectly fine, it's not long had a new recirc either but I'm guessing the ****ty plastic valves are only good for standard so will be updating with a forge one.
(T) help please with error p0240 markab Bravo 7 27-12-2019 17:27
(T) Punto Tjet P0240 HELP please.. mwilde992 Grande Punto 1 03-11-2019 21:47
(T) Punto tjet and bravo tjet inlet manifold Red Rocket CINQ Grande Punto 0 11-03-2016 03:49
(G) Error code P0240 turbo? carlorff Bravo 3 22-08-2013 23:34
