Thread Tools
Old 28-01-2012   #1
rear window washer stopped working
as title says. i have a 06 punto grande thingy, and the rear washer has stopped working. theres no sound or anything.
the front washer works, and i cant see it being the motor, so im thinking fuse maybe? unless they run off the same fuse(like my 306)
the wiper motor still works btw
lou5590 is offline Reply With Quote Quote
Old 31-01-2012   #2
Re: rear window washer stopped working
It's strange that it does not work at all, as both are fed from the same pump literally just different lines. Does the pump make any noise then you try to use the rear washer?
TallTom is offline Reply With Quote Quote
Old 31-01-2012   #3
My first thought was the hose connecting to the rear washer had disconnected somewhere.
Might be worth a look checking where the hose has it's connections first to see if it has come loose.
In the times I've seen this happen it has been the hose come loose.
Abarth grande punto,carbon fibre airbox,various pipes changed,larger intercooler,custom cat back quad exhaust,eibach sportlines,tmc box,protoxide bov,now in matte black
Aaron87 is offline Reply With Quote Quote
Old 06-02-2012   #4
Quote Originally Posted by TallTom View Post
hey again sorry i just realised i posted this in the abarth section :s sorry
anyway, there is no sound from the motor when i do the back wash, the wiper doesnt even move, but i can turn on the wiper and when i select reverse the wiper also goes. if it was a loose hose, wouldnt i still hear the motor goin?
Thread Tools
(T) window washer and flash full beam not working :( sean421992 Cinquecento / Seicento 5 19-10-2009 22:46
(T) window washer not working Aimee83 Punto (Mk2/2b) 2 09-08-2009 19:37
Rear Speakers & sub stopped working Xero I.C.E 4 02-12-2008 14:47
(G) REAR SUNROOF STOPPED WORKING on Multipla coopersan Multipla 2 03-04-2008 19:57
(T) Rear wash - stopped working? Help... h10ndr Cinquecento / Seicento 11 20-04-2005 01:57
