General 2016 595 normal stock boost
googlebear41
Hi
does anyone know how much it should be boosting at ???
its a regular 595 2016 model, all standard
car feels to me like its holding back or has more to give,
no trouble codes , otherwise goes ok , the pod boost gauge only ever goes to 0.8bar / is about 11psi which seems low to me
I have an OBD reader on my phone and its max boost read is 12/14psi
does this sound right??
The pod gauge is peaking at 0.8 bar in sport so seems like i have an issue.
I've checked the small vac pipes for leaks and changed to super unleaded , done a battery reset?? Is there any other suspect areas?
What does it read with the engine off 0 or 14.8 ish
if 0 according to what I have read it should read up
to about 15psi if 14.8 about 30 psi but you will only
get this foot down under load with plenty of revs,
just revving it in neutral wont get you a lot of boots.
foot down in 3rd, 4th or 5th gear , boost gauge holds at 0.8 never goes over. checked hoses all looks fine,
Can anyone tell me where the boost gauge on their car goes too?????
and if yours is a similar car 2016 140bhp 595
2019 Abarth 595 145
Boost goes to 1.0 with foot to the floor...
