I think this 209716H is actually P2097-16.
P2097 is a post cat O2 sensor fault, it's recording a rich reading after the cat.
Rich is generally cool combustion so the O2 sensor produces a low voltage.
O2's aren't your normal sensor, they self generate an electric signal depending on the heat over them, anywhere from 0.1v to 1v.
Lean = hot combustion = higher volts.
Rich = cool combustion = lower volts.
There are generally two sensors on a engine with just one bank of cylinders (and 4 with two banks or V engines).
One pre or before the cat, this one regulates the fuel, it's readings alter how much fuel in injected.
It'll switch back and forth from lean to rich (0.1 to 0.9 or 1v) trying to balance everything out, Low v = rich so it takes fuel away. High v = lean so it adds more fuel.
With everything running ok you tend to get a level trim over time (around 0.45v average between the switching volts) which indictes near perfect fueling
One post of after the cat, this tends to monitor what comes out of the cat and doesn't tend to influence the engines fueling (though on some cars in some markets it can cause limp modes to stop the engine over polluting)
The ECU is just looking if the Cat is doing it's job and the signal is within tolerance (and not mirroring the pre cat signal)
The 16H is a sub section of the fault which helps identify the actual fault, I've no idea what this is sorry, I've never had any diagnostic kit that dug that deep myself.
As you've had the exhaust replaced it might be it's leaking, this will allow exhaust gas to escape and/or draw in air from outside.
This can screw the O2 sensors up, the extra air/escaping gas cools the pre cat O2, it fools the ECU into thinking the engine is rich so it tries to lean it out.
Or if the leak if further back in the exhaust system, it can just cool the post cat O2 causing it to think whatever is coming out of the cat is rich.
