Old 06-03-2021   #1
Netherlands
Very noisy 305mm Brembo brakes.
My Brembo brakes get very noisy under more then average braking.
What could be the cause of that, everything looks ok.
Any Brembo Abarth drivers have/had this issue. ??
There are Pretenders among us.....
Geniuses with the ability to become anyone they want to be.
Abarth 595 Turismo. (195 hp-305Nm)
The Pretender is offline Reply With Quote Quote
Old 06-03-2021   #2
jimboy has donated!
Re: Very noisy 305mm Brembo brakes.
Vibration is the cause. You may be be lucky with brake grease, there are a few choices,or you could fit Teflon shims.
Thanks The Pretender thanked for this post
jimboy is offline Reply With Quote Quote
Old 06-03-2021   #3
Netherlands
Quote Originally Posted by jimboy View Post
So, the solution is to take brake pads out, clean everything, put brake grease on, and put everything back in place. ??
Old 06-03-2021   #4
jimboy has donated!
Quote Originally Posted by The Pretender View Post
Yes, exactly that. Ceramic paste is well thought of.
Old 08-03-2021   #5
Denmark
What kind of noise is it? Is it more than just the extra noise from a disc with vent holes?
I drive with slotted discs in my Saab and the braking noise is quite noticeable.
Multivide is offline Reply With Quote Quote
Old 08-03-2021   #6
Netherlands
Quote Originally Posted by Multivide View Post
Difficult to explain, first time with Brembo calipers brake system.
Let's say, you really hear them work under heavy braking,
Don't know if this is normal for these brakes under heavy use.
Old 09-03-2021   #7
Denmark
You'll probably need confirmation from other Abarth drivers with a similar setup.
My slotted EBC discs and Brembo pads under heavy braking would probably make a person only familiar with smooth discs be unsure if the sound is normal. I would describe it as a "woooooooo" kind of sound
Even then, there is also a difference in sound from vented to slotted discs.
Old 09-03-2021   #8
jimboy has donated!
Mmmm, yes, slotted and vented brakes do tend to make in my experience a grinding sound, I was initially thinking that the brakes were squealing due to vibration. I have a Coupe with Brembo callipers with different slotted and vented discs. I get the occasional squeal, but only on very hard braking do I get that grinding noise which I believe is pretty much normal. This is the sound of pad on disc doing itís job.
Old 12-03-2021   #9
Officina red has donated!
Canít help you with the noise, but damn they look good 👍
Officina red is offline Reply With Quote Quote
Old 1 Week Ago   #10
Netherlands
Some maintenance to the brakes did wonders.
Winter salt did it's number on them.
Likes Olliver, jrkitching liked this post
(T) Noisy brakes / squeeking brakes on Tipo gfitega Tipo (Classic) 2 09-10-2004 11:58
