![]() | #1 | ||
Posts: 46 Thanks: 0 Trader Rating: 1 ![]() | Brembo brakes from Grande Punto Abarth Hey, Hope everyone is keeping well... Wondering if anyone can help. I have Punto Abarth pre-facelift 2008 & also a 2014 pre-facelift 595 Turismo The Punto is fitted with Brembo breaks & calipers front and rear. Does anyone know whether they would be cross compatible on the 595. Both vehicles have 17" wheels. Any help would be very much appreciated. Thanks for looking. ![]()
![]() | #2 |
Posts: 3,483 Thanks: 163 Trader Rating: 0 ![]() | Re: Brembo brakes from Grande Punto Abarth Hey, Hope everyone is keeping well... Wondering if anyone can help. I have Punto Abarth pre-facelift 2008 & also a 2014 pre-facelift 595 Turismo The Punto is fitted with Brembo breaks & calipers front and rear. Does anyone know whether they would be cross compatible on the 595. Both vehicles have 17" wheels. Any help would be very much appreciated. Thanks for looking. ![]() The Punto Evo (2009-2012) has PCD 4x100 and a 56.6mm centre hole.
__________________ There are Pretenders among us..... Geniuses with the ability to become anyone they want to be. Abarth 595 Turismo. (195 hp-305Nm) |
![]() | #3 | ||
Posts: 46 Thanks: 0 Trader Rating: 1 ![]() | Re: Brembo brakes from Grande Punto Abarth Thank you for this... Where did you find this information? So I can check the details for the 595 Turismo. Kind Regards
![]() | #4 | ||
![]() | Re: Brembo brakes from Grande Punto Abarth When you say brembo brakes do you mean 4 pot calipers? Brembo make brakes for all sorts of things so to make this distinction I’m assuming you mean the posh big red multi piston calipers? The rear calipers on your 595 are likely the same as the Punto and may well be brembo anyway, swapping the rears over would be unlikely to improve breaking performance. Brembo calipers can be ‘made to fit’ but then you’d need to match the appropriate discs, usually it’s better to get the brakes off another 595, the discs from the Punto would not be suitable for previously mentioned reasons the stud pattern differs between puntos and fiat 500’s
![]() | #5 |
Posts: 3,483 Thanks: 163 Trader Rating: 0 ![]() | Re: Brembo brakes from Grande Punto Abarth http://www.abarth.com/kit-accessorie...ing-system-kit You need this kit, could be the same as a Punto brembo kit with 4x98 PCD. I run this kit on my serie-4 Turismo.
![]() | #6 |
Posts: 85 Thanks: 6 Trader Rating: 0 ![]() | Re: Brembo brakes from Grande Punto Abarth The discs differ only in regards of the PCD and the center bore. Hight an so on is identical. https://www.bremboparts.com/europe/d...isc/09-8004-7X https://www.bremboparts.com/europe/d...isc/09-B085-13 The question is if the caliper and the braket is the same for Punto and 595. 595 has 4x38mm, but there are also 4x40mm existing. I don´t know if the Punto Abarth has the bigger ones.
__________________ Best regards Oliver 595C Turismo |
![]() | #7 | ||
Posts: 3,483 Thanks: 163 Trader Rating: 0 ![]() | Re: Brembo brakes from Grande Punto Abarth My Brembo’s are the floating discs version.
![]() | #8 |
Posts: 85 Thanks: 6 Trader Rating: 0 ![]() | Re: Brembo brakes from Grande Punto Abarth Saves 1,6kg! ![]()
![]() | #9 | ||
![]() | #10 | ||
Posts: 85 Thanks: 6 Trader Rating: 0 ![]() | 🤣
![]() | MikeAGR | Grande Punto | 0 | 07-02-2016 01:05 |
