Old 12-11-2020   #1
Germany
Pin assigment high beam / DRL / pos. light?
Hello guys,
can anybody here help me with the pin assignment if the DRL/hig beam's connector? So in my opinion the little thicker green one, close to the black one ist for the high beam, black is common ground. But Iīm not sure with the thinner green one and the yellow one, which is for DRL and which for position light??
Thanks a lot!
ID:	213794   Click image for larger version
Best regards
Oliver
595C Turismo
Olliver is offline Reply With Quote Quote
Old 12-11-2020   #2
It's always more involved
John202020's Avatar
John202020 has donated!
Re: Pin assigment high beam / DRL / pos. light?
So it should be possible using a meter and the respective lamp holder inside the cluster to work out which pin does what ?
From the book,
Black ground/negative
Yellow/black stripe DRL feed right hand side, green/yellow stripe left hand DRL
Green/yellow stripe right hand side light, yellow/red stripe left side light
Note there is one wire colour(green/yellow) on each side with the same colour but has different functions!
Likes Olliver liked this post
30 years of Honda Accords, now Mazda 6 and a Fiat 500
John202020 is offline Reply With Quote Quote
Old 12-11-2020   #3
Germany
Hello John,
first of all thanks for that information. Surely I could have measured it with a meter, but I was asking here hoping that somebody knows it. As with the Abarths relatively big tires and lowering, you need to at least jack up the car to get access and work to some extent at the connector, better remove the complete wheel. Itīs winter, dark and cold...honestly said I wanted to avoid this and create the load adapter on the desk.
Basically I want to do the same like this guy https://www.fiat500owners.com/thread...tor-mod.15698/ but he did for an US model (with turnlight instead of hig beam located in there) and I donīt want to solder on my original wiring harness, due to the fact the vehicle is quite new and an I donīt want to loose guarantee....
Best regards
Oliver
595C Turismo
Old 18-11-2020   #4
Germany
So this will be the assignment according to your information for the left side:
And it fits also to the posting of the guy who did this to his US-model.
But what I donīt understand is, why Fiat didnīt use the second of the two inner pins for the high beam, as they are bigger and so can handle higher current? That the ground pin was one of the inner pins was clear to me, but why they connected the DRL to it? DRL is only 21W, high beam is 55W....for US models itīs not a problem as instead of the high beam, it has only to handle the indicator.
ID:	213958   Click image for larger version
Best regards
Oliver
595C Turismo
Old 18-11-2020   #5
John202020's Avatar
From the Haynes manual for 07-2012
ID:	213963   Click image for larger version
Old 18-11-2020   #6
Germany
Hello John,
please donīt misunderstand me, I didnīt want to question your post, I was totally believing in it. I was only wondering why Fiat did it this way. Thatīs all.
You can clearly see the inner pins are bigger.
Best regards
Oliver
595C Turismo
Old 18-11-2020   #7
John202020's Avatar
Quote Originally Posted by Olliver View Post
Hello John,
No problem just thought this would make it as clear as possible to help you, if you need the high beam wiring image let us know 😀
Old 19-11-2020   #8
Germany
No thanks, I think the high beam wiring is not necessary. I now got the male socket housing, only waiting for the pins...then I can start assembling the adapter. Female socket is no problem as it is offered already with cables as repair kit for the wiring harness on ebay and co. .
ID:	213968   Click image for larger version
Best regards
Oliver
595C Turismo
Old 19-11-2020   #9
John202020's Avatar
Are you fitting LED's ?
Old 19-11-2020   #10
Germany
Yes I want fit LEDs for DRL, but I want to be able to remove everything without remains. So no mods to the original wiring harness. First I was trying fit everything inside the beam, but there is not so much space left, as the high beams are already also LED and the resistors became quite hot and I also didnīt wont to cut the rubber cap to keep then outside. In addition the aftermarket 7440 sockets didnīt fit good in the beam...so I went for this solution.
Best regards
Oliver
595C Turismo
Old 19-11-2020   #11
John202020's Avatar
If you use several resistors in parallel then they will not get as hot and are smaller but you have more of them ?
Old 19-11-2020   #12
Germany
For the "inside solution" I used two 33Ohm / 10W ceramic resistors in parallel. For the adapter cable I will assemble now, one 15Ohm / 25W resistor with metallic housing that is able to handle 12,5W @ 25°C beeing mounted free air.
https://www.vishay.com/docs/30201/rhnh.pdf
Should be enough, but to be on the safe side I will attach a small additional heat sink to it.
Likes John202020 liked this post
Best regards
Oliver
595C Turismo
Old 21-11-2020   #13
Germany
So since today I know, that the Haynes manual is not valid for my car. Is it due to the fact itīs a face lift vehicle (year 2020)? Or is the plan in Haynes manual only for US models? So my colours are different, gren-yellow is DRL, thick green is high beam black ground, and yellow is position light.
But in the end it worked without an error message in the dash.
ID:	214013   Click image for larger version
ID:	214018   Click image for larger version
ID:	214020   Click image for larger version
Best regards
Oliver
595C Turismo
(T) Bulb Out warning light on high beam, but replaced the blown bulb! aqibi2000 Grande Punto 1 29-06-2018 16:27
(T) left low beam not working, high beam working andy1 Panda 15 20-12-2015 10:07
(T) High Beam Dash Light Paul106xsi Stilo 0 23-11-2015 18:33
High Beam goneleft Leisure Lounge 9 21-12-2007 01:50
(T) High Beam arsedownoz Multipla 1 12-02-2007 14:10
