Mathias1977
- Jan 20, 2020
- 1
- 1
Hi Abarth friends,
I am trying to figure out why my Fiat 500 Abarth is making such an odd sound. This is my second one and my previous 500 did not make this noise when releasing the gas pedal after accelerating.ehat can this noise be? The actuator failing perhaps? The turbo pushes strong (although I do feel a "dip" around the 3,000 rpm mark).
I'm also curious to know why the actuator rod doesn't seem to be moving on this video as I'm releasing the gas pedal. Does the engine need to be under load in order for the actuator to actually do its job? I would have thought that he would have worked even if I would accelerate and release the gas pedal while static.
Video here: youtu.be/JMo65VhJyVA
Any help is appreciated!!
Thank you,
Mathias
Thank you,
Mathias
