Hi Guys
a Little puzzled here so hoping you guys can give me a hand.
The 500 has a compression ratio of 9.8:1 and boosts a bar or 14.5 psi. That gives you a final compression of around 20.
According to charts, anything above 12.4 final compression will cause detonation on pump gas so how do these motors run then?
Need the info for a build as we need to lower compression to run higher boost.
Thank you
Thank you
