Thread Tools
Old 18-08-2019   #1
Door handle problems... But not the hinge this time!
Last year I had the very common door handle hinge problem which was an easy fix I did myself, just replacing the hinge.
Now a new problem has developed where the highlighted rod in the photo below pops out far too easily, meaning that even when I put it back in place, it only takes a few times for the door shutting to vibrate /knock the rod out of the slot. This means I can't open the door from the outside, and my MOT is due October so need to sort this sooner rather than later. My poor attempt of tying string to keep the rod in place didn't work (surprise surprise), so anyone have any idea what I can do that will keep the rod in the slot, or if I need to replace the unit and if so what is it called? Thanks!
Blonde126 is offline Reply With Quote Quote
Old 18-08-2019   #2
Fiat 500 Devotee
werdna's Avatar
werdna is part of the official FF Events Team :)
werdna has donated!
Re: Door handle problems... But not the hinge this time!
https://www.aecar.co.uk/ They do the clips that hold the rods in place.
Likes Blonde126 liked this post
werdna is offline Reply With Quote Quote
Old 18-08-2019   #3
Quote Originally Posted by werdna View Post
Thank you, wasn't sure if there was something that was meant to hold the rod in place or not, as it seems to fit in the slot but not stay! Must have pinged off in the past. Also my photo didn't upload, will see if I can update post.
Fiat 126 | Abarth 595 Comp 180
Old 18-08-2019   #4
Quote Originally Posted by Blonde126 View Post
Here's the image:
Likes werdna liked this post
Old 19-08-2019   #5
Fiat 500 Devotee
werdna's Avatar
werdna has donated!
Yup. That's a true picture ! I ordered two blue clips for the rod at the back, after measuring the rods ( near as dammit identical ) and changed the blue and white ones for two blue ones.
Old 20-08-2019   #6
I just use thin cable ties. You can feed one through the hole in the silver bit and wrap it round the rod. If you donít do it up too tight it holds it perfectly. Done it numerous times. Works every time.
typecastboy is offline Reply With Quote Quote
Thread Tools
(G) Door Handle Hinge - whats next ..... TTR 500 4 06-12-2018 07:03
(G) Broken door handle hinge Daveu 500 1 09-05-2018 23:37
(G) That damn door handle hinge! typecastboy 500 78 02-06-2017 23:26
(T) Door handle. Will hinge repair work here? Drpellypo 500 4 10-12-2015 14:32
Need a drivers side door handle hinge, can anyone help?? slats1970 FIAT Boo Archives 0 21-10-2003 18:41
