So are saying that whenever you come to a stop for an extended period, you have to put it in neutral?
You don't have too, but it's wise.
When you think how it works, leaving it in gear for extended periods also continually runs the hydraulic pump (this acts as the clutches master cylinder) that activates the clutch slave cylinder to hold the clutch pressure and friction plate apart.
I'm pretty certain this caused a problem with the EGS system I had in a Citroen.
I took it for a valet and they left it running with the heater on full to dry out, I'm pretty certain it was left in drive with the pump running and the hydraulics under continual pressure.
I didn't think much of it until I noticed a oily drip from the bell housing a week or so later. It wasn't there before I know, otherwise the drive would have been stained.
I took it in to my local gearbox specialist who checked it and said the slave cylinder was leaking.
Due to the electronics they needed Citroen software to reset the system and prime the hydraulics after replacing the slave and reassembly, they just weren't equipped to replace it, they just topped up the hydraulic fluid and told me to take it to the dealers, which I did.
The dealer confirmed the slave was leaking and quoted me £1500 to replace a £25 part.
I shopped around a few indie Citroen specialists and the best I got was "We've never done one of them but we'll give it a go" for £1100.
It wasn't really my car, I inherited it and didn't really need it, so I got rid of it.
I couldn't prove the valet caused it, it could have been due to the car being stood idle for so long, but it did make me think they aren't the most reliable systems and big bills come pretty much as standard with them, which brings my back to the choice of the Renault Clio's EDC, it comes with 5 years warranty!
