Old 20-06-2018   #1
USA
PO351 & PO301 for all cylinders
I'm getting these codes for all the cylinders. Is this an ECI issue? Where should I start to diagnose this? Thanks
GradyWhite is offline Reply With Quote Quote
Old 21-06-2018   #2
Goudrons has donated!
Re: PO351 & PO301 for all cylinders
P0351 is Ignition Coil A, Primary/Secondary Circuit Malfunction.
That would cause P0301 - Cylinder #1 Misfire if that coil is playing up.
I believe each cylinder has it's own "pencil" coil on top of each plug, "A" is number 1 cylinder. (P0301 is misfire on number 1 cylinder).
You could try clearing the codes, then swapping cylinder 1's coil over with another and see if the issue moves with that particular coil.
If it does and you get a new set of codes relating to the cylinder you moved the coil too, then it's that individual coil that fubar.
If it doesn't move, you've likely a wiring issue to number 1 coil.
Goudrons is offline Reply With Quote Quote
Old 21-06-2018   #3
This shows you how to get at the coils.
Number one is usually at the end furthest from the gearbox (left as you stand in front, though it's on the right in the vid as it's filmed from the back of the engine bay)
Old 21-06-2018   #4
typecastboy has donated!
They are numbered 1,2,3,4 from left to right and in relief print on the coil pack itself.
typecastboy is offline Reply With Quote Quote
(T) Punto 1.2 8V not firing on Cylinders 1 & 2. armysurplusspecial Punto (Mk2/2b) 13 16-06-2015 09:07
(T) Error PO351,PO352 ignition coil ongoing electrical gremlins stmterrace Multipla 0 19-05-2014 08:15
(T) 51 Bravo 1.2 running on cylinders 3 & 4 only Snapple Bravo / Brava 6 27-01-2010 21:16
(T) Master Cylinders & Servos a73uk Tipo (Classic) 3 20-06-2009 01:17
(T) Ignition failure on cylinders 1 & 3 causing faulty ECU ??? Kittykatryn Stilo 1 03-10-2006 14:43
