im Axle Specialists
Old 01-05-2018   #1
TerrorTag has donated!
Replacing Blue & Me USB
Hi All,
I need to replace the blue and me USB/aux connector as my USB has broken. Does anyone know how easy this is to replace? Do I need to remove the whole surround with the cup holders?
Thanks in advance
TerrorTag is offline Reply With Quote Quote
Old 01-05-2018   #2
Re: Replacing Blue & Me USB
Piece of cake!
Insert a trim tool or or a slim screwdriver under the usb unit already fitted to the car and gently prize it out. Once you lift it you will be able to get your fingers under it and pull it out along with the cables.
The usb cabling is connected to the bottom and held securely by a plastic clip that you have to fold back to release it. You will need to push down the plastic lock tab that holds it in place. Then you can push the blue plastic retainer back that will release the connector. This bit is fiddly but once you get the idea of how it comes off its straight forward.
Fitting really is the reverse of the above.
Thanks Rocco Reviews, TerrorTag thanked for this post
Likes jtdneil, TerrorTag, 306maxi liked this post
Earlofdavetona is offline Reply With Quote Quote
Old 01-05-2018   #3
Thanks very much, I've just ordered the part so the wait begins
Old 02-05-2018   #4
No strings on me
Eklipze3k's Avatar
Eklipze3k has donated!
I've just had to do this in my MiTo and it was a 2 minute job. Sadly, the previous owner tried to do it by removing the gear stick gaiter, and broke all the clips!
Eklipze3k is offline Reply With Quote Quote
Old 3 Weeks Ago   #5
Just tried removing mine easy as, does anyone know how easy a replacement would be to source and fit?
DomJayLee8 is offline Reply With Quote Quote
Old 3 Weeks Ago   #6
No strings on me
Eklipze3k's Avatar
I got mine off ebay, 2 min job to fit
(T) Bravo Blue&Me USB upgrade to AUX + USB tishka383 Bravo 17 29-12-2017 12:09
Blue & Me + USB & AUX set up tishka383 Blue and Me 0 14-03-2017 17:40
Easily Add AUX to USB only Blue&Me (Alternative to Blue&Me Adaptor) CBrindle Blue and Me 1 23-11-2014 21:59
Blue & Me - File/Folder/Artists/Genre etc - USB Stick &/or CDr .? Dickthebuilder Blue and Me 2 01-11-2009 13:44
