FIAT Auto Specialist Team
Old 30-12-2017   #1
Blue&Me Module Location
Hi all.
Iíve just done a double-DIN modification to our Abarth 500C (12 plate but think might be 2011 model-year car...how can I tell?)
The Connects2 install kit came with a cable to connect into the Blue&Me module to allow the original USB socket to be used.
For the life of me I canít find the module location..the wires from the USB socket seem to head from the socket left under the carpet towards the LHS (passenger side in UK) door area.
Can anyone tell me where it is?
Thanks. Ben
benkay is offline Reply With Quote Quote
Old 30-12-2017   #2
Mercky has donated!
Ireland
Yes your right, I Seem to recall itís behind the near side trim panel by the rear seats, not 100% though so double check ! I know the amp for the interscope audio is on the other side
Mercky is offline Reply With Quote Quote
Old 30-12-2017   #3
typecastboy has donated!
Re: Blue&Me Module Location
Yes it is. Take out the rear seats and remove the near side panel.
Likes benkay liked this post
typecastboy is offline Reply With Quote Quote
Old 30-12-2017   #4
Thanks. Any idea what the Connects2 Blue & Me extension cable is actually for then? It looks to be an extender for the big fancy blue connector, with a USB pigtail.
I’m almost tempted to forget the original usb socket, but the.n does anyone know how blue&me could be de-activated/disconnected as all Bluetooth is now through the new head unit.
This is an image of it :
Old 31-12-2017   #5
UFI
500 TwinAir Plus
UFI's Avatar
UFI has donated!
Australia
Quote Originally Posted by benkay View Post
Iím almost tempted to forget the original usb socket, but the.n does anyone know how blue&me could be de-activated/disconnected as all Bluetooth is now through the new head unit.
If you've removed the OE HU, you've already disconnected B&M.
The module may be drawing some standby power (and adding a little weight), other than that it's probably not worth perusing unless you do it while the car is apart for some other job (like rear speakers).
2012 Fiat 500 Twinair+ 2016 Renault Trafic dCi140 LWB 2009 Proton Arena 2005 Jeep Wrangler 2005 Toyota Prius 1989 Nissan Skyline 1949 Ford F1 255 V8
UFI is offline Reply With Quote Quote
Old 03-01-2018   #6
I'm not sure it is though.
If I hold down the "Call" button on the steering wheel, the dash display (inside speedo) still tries to show "last calls" etc. for about 2-3 seconds before cancelling itself out.
If I disconnect the Blue & Me module entirely, would that stop happening?
Old 12-04-2018   #7
Netherlands
Did you already found a solution @benkay?
I also replaced my radio unit and blue&me is giving the same response when pressing the call button, etc.
sailorbel is offline Reply With Quote Quote
Old 13-04-2018   #8
Trader Rating: 1
alexGS has donated!
New Zealand
To avoid confusion in the instrument panel (timeouts, etc.) I suggest that a proxy alignment would be a good idea, to record the removal of the Blue&Me unit. MultiECUScan software can do this.
Does the Connects2 interface connect to the CAN bus to enable the steering wheel controls? If so, perhaps it masquerades as the Blue&Me unit - in which case, proxy alignment would disable it (not a good idea then).
-Alex
'15 Giulietta 1.4MA, Ď14 Abarth 500C Esseesse, '08 500 Lounge 1.4 Dualogic, '08 G Spyder, '71 850 Coupe in bits...
alexGS is offline Reply With Quote Quote
(T) This is the location of the Blue & Me ECU typecastboy 500 5 05-07-2016 09:29
(T) Can Blue&me Module be replaced? bobbycarver Grande Punto 2 20-02-2015 12:59
Fiat 500 lounge 2008 Blue & Me unit location sorcli Blue and Me 2 09-10-2013 18:07
(T) Blue & Me ECU Location Most Easterly Pandas Bravo 8 10-09-2012 16:41
location of fuse of Blue & Me yariv Blue and Me 1 07-09-2010 15:39
