im Axle Specialists
Old 22-10-2017   #1
chris3234 has donated!
09 500 sport scuttle area full of water
i have a 2009 1.3 mulijet sport and the area under the windscreen is full of water
i assume threes supposed to be a drain area someplace anyone direct to it to try and clean it out?
edit: just noticed this is the Abarth section its its normal 500 if somebody can move it
chris3234 is offline Reply With Quote Quote
Old 22-10-2017   #2
Re: 09 500 sport scuttle area full of water
ah never mind found it now
had to take the scuttle cover off with the three type push pins then remove the wiper blades so i could move the cover out of the way
then after blasting the are out with an air compressor i manged to dislodge enough crud for it top start draining and made me able to see the the drain points was previously covered in filthy sludgy water
the drain is in the little recessed are around the center a small rubber lined hole/ tube
gave it a good flush with warm sopay water and used a bottle brush to clean both side drains holes out the one of the other side is block by the wiper mechanism and you cant get your hand near it
(T) Water in scuttle area...do I really need these boots? underlay underlay 500 4 03-01-2017 23:22
500 New Fiat 500 Sport with Full Bodykit PlopHole Members Motors 53 29-02-2016 18:59
(T) Removing fiat 500 scuttle panel Cumminz 500 4 05-09-2014 12:29
(T) Water Leak from Clutch area Steveball Cinquecento / Seicento 15 30-12-2007 19:06
