Hi All,
My Springs have given up, I can see on ebay a cheap pair of abarth standard springs, will these fit the front and back with the same (new) shocks?
fiat 500 2014 1.3 multijet
Thank you
Thanks, do you have any thought on this little mod?
I just wondered if I put new oem suspension on and have the abarth springs as a nice treat?
Thanks for your help. It's done 70k the shock are weeping alot and say that I should replace them and the springs arent in good shape. I just wondered if I put new oem suspension on and have the abarth springs as a nice treat?
Even heavier than the ABARTH 1.4? It's known that mounting ABARTH SS springs on a 500 TA increases the ride hight instead of lowering it.They may physically fit but the multijet is quite a lot heavier than petrol engines cars
I didn't change my drop links when I changed my springs so I'm gonna say no.Out of interest, if lowering, do you need shorter drop links?
I guess the bar just sits lower at each end?I didn't change my drop links when I changed my springs so I'm gonna say no.
Tom
Emmmm....yes.....I guess the bar just sits lower at each end?
