I'm driving it again on Wednesday this week, so I'll experiment.
Just completed my duties with the Wednesday drive.
The gear knob sits centrally when driving normally.
Flip it the left, and it toggles between Manual and Automatic.
When stopped, you can select Neutral by moving the lever right and up.
Also, you can select Reverse by moving the lever right and down.
Also, depending in which you were in, you can be in Auto or Manual Neutral, or Auto or Manual Reverse. Next time you put the lever to the centre, it automatically goes to Auto or Manual depending on what you had it set to last.
Now, back to the original point ................
If in Reverse, you flick the the lever upwards and it automatically goes into 1st gear (Auto or Manual depending on what you wanted).
If in Neutral, it automatically goes into 1st. No need to select 1st. It always goes there. Even whilst driving in Manual, if you stop or go slow enough, 1st is always selected.
Therefore I still cannot for the life of me understand what the 1st button is for on the New Look.
Best wishes,
Mick.
