![]() | #1 | ||
Posts: 22 Thanks: 0 Trader Rating: 0 ![]() | not the usual knock hello im wondering if anybody has had the same problem. i had a knock from the rear so i replaced the shockers as bushes split, noise was still there so i fit some polybushes in the shockers noise still there! i then replaced the axle bushes fit some lowering springs and bumpstops and to my dismay noise still there!i put a new stainless exhaust on and this also made no difference, the knock is doing my head in any ideas?
![]() | #2 | ||
Posts: 197 Thanks: 8 Trader Rating: 0 ![]() |
![]() | #3 | ||
Posts: 22 Thanks: 0 Trader Rating: 0 ![]() | Re: not the usual knock hello thanks i checked them when i replaced the axle bushes they were intact
![]() | #4 | ||
Posts: 53 Thanks: 1 Trader Rating: 0 ![]() | Re: not the usual knock what was the outcome with this? thanks
![]() | #5 | ||
Posts: 22 Thanks: 0 Trader Rating: 0 ![]() | Re: not the usual knock hello i think its coming from the fuel tank area either something has collapsed inside or the tank is moving, there is nothing else in the area i have had it on a ramp and there is no play or movement in any of the suspension, i have not had chance to investigate further. Do you have the same issue?
![]() | #6 | ||
Posts: 53 Thanks: 1 Trader Rating: 0 ![]() | Re: not the usual knock Well from new I had a knock every time I hit a bump or drain cover etc but after a few weeks it's gone, at least I don't hear it anymore
![]() | #7 | ||
Posts: 3,843 Thanks: 168 Trader Rating: 0 ![]() | Re: not the usual knock I too have a noise sometimes and have had new shocks all round did wonder if it was the aftermarket exhaust trim I fitted hitting the bumper as there's only about 30mm clearance ?
![]() | #8 | ||
Posts: 53 Thanks: 1 Trader Rating: 0 ![]() | Re: not the usual knock well mine was standard and i still had it, maybe its something bedding in? Seems strange if it is, but mines gone so maybe something has fallen off. ![]()
![]() | Chris RWatts | Abarth Grande Punto | 8 | 05-03-2015 17:03 |
![]() | sleeka1 | Cinquecento / Seicento | 2 | 25-03-2014 23:16 |
Punto (Mk2/2b) Problems as usual! | James MK2 | Newbie Central | 1 | 31-07-2012 18:55 |
![]() | JimMagill | Panda (Classic) | 6 | 06-09-2007 01:04 |
![]() | Freebeer | Punto (Mk2/2b) | 7 | 07-11-2006 14:35 |
