Thread Tools
Old 11-03-2016   #1
Canada
Mystery part in my Abarth
I have a mystery part that broke inside my 2015 Abarth and the dealership has no clue where it came from.
This happened when the car was at at a stop light suddenly there was a very loud pop sound in the car. After getting home, I checked my driver seat and looked at the back and found the broken pieces on the floor mat. I have no idea where it's from? The size of the largest piece is just over an inch long. The only letter or numbers on the larger piece is "B4". Not sure if it is from adjusting the driver seat all the way back and all the way forward?!?!
And does anyone know how to contact the manufacture? They must know as they are the ones that built the car?
Has anyone seen anything like this before? Any suggestions or advice would be greatly appreciated!
ID:	165577   Click image for larger version
Supasweet is offline Reply With Quote Quote
Old 11-03-2016   #2
It's always more involved
John202020 has donated!
Re: Mystery part in my Abarth
Look for a hole the size of the outside ribbed bit? Maybe with a screw or something in the middle
John202020 is offline Reply With Quote Quote
Old 19-03-2016   #3
Is that not a clip that holds the floor mat in place?
DrogoD is offline Reply With Quote Quote
Old 19-03-2016   #4
Well the larger piece is all in tact and looks like the fragments are from an matching/opposing piece all of which is not there so having a good look under the seat should help locate the remaining pieces and give you some idea where it is from, but to be honest it just looks like a trim clip
Maker and voice behind the YouTube channel PuntoHowTo 10k subscribers canít be wrong
And now the owner of a shiny new PuntoHowTo Drivetribe
AndyRKett is offline Reply With Quote Quote
Old 19-03-2016   #5
Australia
Appears to be some type of two-piece grommet that snaps together around a cable or such before being pushed into a hole. Might be related to the seat sensor cabling.
Likes alexGS liked this post
Piccolo Nero e Bella is offline Reply With Quote Quote
Old 20-03-2016   #6
UFI
500 TwinAir Plus
UFI's Avatar
UFI has donated!
Australia
Quote Originally Posted by Piccolo Nero e Bella View Post
My guess would be the cables that allow the seat to be pushed forward for rear access.
Thanks alexGS thanked for this post
UFI is offline Reply With Quote Quote
Old 20-03-2016   #7
Australia
Quote Originally Posted by UFI View Post
Yes UFI, on reflection electrical cables wouldn't survive the kind of tension needed to make it explode like that - that's tough plastic. Had a (limited) look under my seat today with the aid of a mirror but I can't see anything like it - mind you, mine's not an Abarth.
Old 22-03-2016   #8
Trader Rating: 1
alexGS has donated!
New Zealand
As AndyRKett said, inspection of the intact half reveals that an identical half originally fitted against it (protrusions on one side, recesses on the other). Although it resembles a trim clip at first glance, it is clearly a bit more complicated (more exact design and smoother (harder?) material) and fits around something in situ, as Piccolo Nero e Bella said.
I think it is a grommet/guide for a pull-cable inside the driver's seat - and tension, perhaps from weight against the seat somehow, shattered the hard/brittle plastic suddenly. I suggest checking all the seat functions carefully (seat slide, height adjust, backrest tip forward, etc.) and if anything is not working smoothly (or feels like a cable dragging against something), get it back to the dealer for remediation before the cable is damaged. You might also notice that one of the levers is loose, because the outer ribs are probably used to set the cable tension - with the pieces gone, the cable will probably be flopping around.
I had to replace a broken cable in a Multipla seat recently, because it had frayed against the seat pan/base. Each design is different and I have not looked at an Abarth seat yet, but many designs rely on these pull-cables (a Bowden cable but made of multiple strands spiral-wound, for flexibility).
-Alex
Likes Piccolo Nero e Bella liked this post
'15 Giulietta 1.4MA, Ď14 Abarth 500C Esseesse, '08 500 Lounge 1.4 Dualogic, '08 G Spyder, '71 850 Coupe in bits...
alexGS is offline Reply With Quote Quote
Old 22-03-2016   #9
Australia
I think you're right Alex. I could see those pull cables under my seat. They're sleeved in black plastic tube which sort of fits with the shape of that grommet.
Thread Tools
(T) Mystery part -what is it and where does it go? wildcat_lgf Stilo 5 29-05-2012 10:02
(G) "Abarth Martini Racing Ritmo convertible 100S Mystery????? " dretceterini Ritmo / Strada 57 04-09-2009 12:58
(G) Cinq Abarth Part No's Help pedrocinq Cinquecento / Seicento 6 10-05-2009 11:24
(T) Abarth ac compressor part no please. Geoff Stilo 2 04-06-2007 21:45
(S) Abarth Part Numbers richydraper Cinquecento / Seicento 7 28-02-2007 22:59
