Old 29-04-2014   #1
Trader Rating: 1
dannyfiatman has donated!
Angry Jacking a fiat 500 abarth
Where do you jack the fiat 500 abarth up from i tried to change my alloy wheel at weekend with standard low jack but the jack hit the side skirt before it hit a jacking point.
dannyfiatman is offline Reply With Quote Quote
Old 29-04-2014   #2
Speed Reader of the Year!
Most Easterly Pandas's Avatar
Trader Rating: 2
Most Easterly Pandas has donated!
Re: Jacking a fiat 500 abarth
Quote Originally Posted by dannyfiatman View Post
I didn't even think the Abarth's came with a jack or space wheel? I know my mates didn't.
Get a normal hydraulic jack (its far safer than the emergency scissor jack) and place it under the front sub frame, or rear sub frame under the spring housing
Most Easterly Panda's - Panda'ing in East Anglia
Stockest of mk2 Panda Parts, PM for any parts requests
1993 Classic Panda Selecta, 1989 Panda 750L,
2015 Kia Soul EV, 2009 Qubo Dynamic Dualogic WAV & 2005 Panda Climbing 4x4 (LPG)
Most Easterly Pandas is offline Reply With Quote Quote
Old 29-04-2014   #3
Murano16v has donated!
It's a bit pathetic that with Abarth you get no wheel brace and no jack.No doubt it's Abarth's attempt to make you take it to the dealer for everything.
I've just bought a universal scissor jack with the slot for the sill joint. The slot was not deep enough and the jack would hit the side skirt. So I've welded on some steel bar to raise the height at the top. it's good and strong and fits perfectly now.
Likes dannyfiatman liked this post
Murano16v is offline Reply With Quote Quote
Old 29-04-2014   #4
Trader Rating: 2
Quote Originally Posted by Murano16v View Post
Probably more to do with weight reduction and emissions.
Old 29-04-2014   #5
STOP! Hammer time!
306maxi's Avatar
306maxi has donated!
Nah, they probably don't want to have to design a new lower scissor jack.
Likes dannyfiatman, 44sunsets liked this post
306maxi is offline Reply With Quote Quote
Old 29-04-2014   #6
This is the hilarious quote from the owners manual.
"As a result of it's sporty nature, the car is fitted with aerodynamic spoilers at the bottom and miniskirts at the side. If the vehicle needs to be raised, go to an Abarth Dealership which is equipped with arm lifts and workshop lifts ".
Under all the stick on bits it's still a 500 shell and there is no reason not to jack it yourself and less chance of getting dealer damage.
Old 29-04-2014   #7
Trader Rating: 1
Abarth said refer to my handbook which states take it to an abarth dealiship where they are equiped with special equipment to lift car up. I am guessing a ramp but my point of view is what are you meant to do if you are on hard shoulder with a side wall damage ( which wont fix) . If you call a recovery van to change wheel they wont be able to jack car up.
Old 29-04-2014   #8
STOP! Hammer time!
306maxi's Avatar
But Abarth's are special cars and not just lowered they 500's.
Old 29-04-2014   #9
STOP! Hammer time!
306maxi's Avatar
Wish you'd bought a car from a manufacturer that's a bit more competent?
Old 29-04-2014   #10
Trader Rating: 1
I have discussed with abarth the situation they have told me to go and see them on Saturday. Which i will and i will post what they say about the situation.
Old 29-04-2014   #11
STOP! Hammer time!
306maxi's Avatar
The problem is there is nothing that they can do, well I suppose there are things they could do, but they won't do any of them.
They've designed a car which you can't jack with the standard jack, not included any jacking tools and have warned you about this. As far as they're concerned they've done their bit.
Old 30-04-2014   #12
72 Year Old teenager
chas379's Avatar
Trader Rating: 1
chas379 has donated!
From what I remember the type of jack needed is a low entry one. The only scissor jack to do the job is from, would you believe, an old Hillman Imp. But of course scarce to get hold of.
Other than that you can but Low entry Hydraulic jacks.
[SIGPIC]
chas379 is offline Reply With Quote Quote
Old 03-05-2014   #13
I've jacked mine up using a low entry trolley jack as stated above. I'd recommend a 1/2 to inch thick block of wood to get a little extra clearance. If you look under the car just at the door/wing meeting point there are a pair of box sections hanging down with circular cut outs - use those. There is something similar at the back but covered by plastic on mine. As the car is so small it's possible to take both wheels off on one side.
DO NOT use the sills or chassis rails as it's easy to damage and in the early days even dealers were caught out.
Boodajuda is offline Reply With Quote Quote
Old 03-05-2014   #14
Trader Rating: 1
Thank you all for advice i have found a scissor jack which actually works i tried my low profile jack but it kept on hitting the side skirt. Much appreciated for you advice and abarth was not useful on the situation to be honest.
Old 17-03-2015   #15
Hi dannyfiatman
any chance you can tell me what the jack is that you have found that works?
Many thanks
dark night is offline Reply With Quote Quote
(T) Jacking the 500 (again) staffordmike 500 15 07-02-2021 22:58
(T) 500 jacking/ lifting/ axle stand positioning Andy Monty 500 41 08-11-2020 21:30
(T) Jacking-up the 500 FireballXL5man 500 10 07-04-2013 17:23
(G) Jacking punto MK2 with abarth side skirts beck_4ever Punto (Mk2/2b) 7 21-09-2006 15:12
