im Axle Specialists
Old 17-03-2015   #16
RUI
Get Your Own Tile
RUI's Avatar
RUI has donated!
Re: Jacking a fiat 500 abarth
This is what most people do.
Likes chas379, snes, dannyfiatman liked this post
RUI is offline Reply With Quote Quote
Old 17-03-2015   #17
72 Year Old teenager
chas379's Avatar
Trader Rating: 1
chas379 has donated!
Quote Originally Posted by RUI View Post
Correct, there is always a solution, RUI never fails!!!
[SIGPIC]
chas379 is offline Reply With Quote Quote
Old 17-03-2015   #18
Trader Rating: 1
dannyfiatman has donated!
Quote Originally Posted by dark night View Post
Hi dannyfiatman
any chance you can tell me what the jack is that you have found that works?
Many thanks
I bought a standard scissor jack and took it to work for a big block to be welded to the top of it so it does not hit the side skirt .
I will try get a picture later jack in garage.
dannyfiatman is offline Reply With Quote Quote
Old 21-03-2015   #19
Don't get me started on the whole 'jacking' issue with all 500's and garages / dealers in general... Feel my blood pressure rising already. There's hardly a 500 out there without damage from incorrect 'correct' jacking
The Twins is offline Reply With Quote Quote
Old 21-03-2015   #20
Speed Reader of the Year!
Most Easterly Pandas's Avatar
Trader Rating: 2
Most Easterly Pandas has donated!
Quote Originally Posted by The Twins View Post
I viewed 3 500's in December for sister, we bought the 3rd and it was the only one with front end sill damage caused by incorrect jacking. It's shocking how common it is!
Most Easterly Panda's - Panda'ing in East Anglia
Stockest of mk2 Panda Parts, PM for any parts requests
1993 Classic Panda Selecta, 1989 Panda 750L,
2015 Kia Soul EV, 2009 Qubo Dynamic Dualogic WAV & 2005 Panda Climbing 4x4 (LPG)
Most Easterly Pandas is offline Reply With Quote Quote
Old 21-03-2015   #21
varesecrazy has donated!
With.. or Without damage..
Personally..,
I drive onto Low-ish blocks, then you've enough room to get under with a conventional trolley jack.. don't trust FIXED point jacks as the car will ALWAYS creep sideways
AND I always jack on suspension points,
NEVER damaged a sill..!!
unlike a friend who got back in his Vauxhall at a major fast-fit chain to find they had jack-ed up the floor pan ( at the drivers footwell)
Old 21-03-2015   #22
Trader Rating: 2
Quote Originally Posted by varesecrazy View Post
Personally..,
Well spotted, my bad, it was the only one without. The first 2 each had front end sill damage.
Old 21-03-2015   #23
how is the TwinAir then Jon ?,
not heard mention since the oily turbo pipe mystery..,
Charlie
Old 21-03-2015   #24
Trader Rating: 2
Charlie
It's not too bad. Oil leak is being fixed this Thursday funny enough, been really busy so had to find time to get it taken into our Alfa/Fiat specialist in Norwich to have a look. Took it in for them the clean the engine bay down as there was oil everywhere so no hope in finding the source, then back about 10 days later to see where it's coming from, and it's some strange plastic coolant pipe / plate which appears to have an oil feed within it also. Seems the plastic has warped causing the oil leak. 35 for the part and then fitting on top. So hopefully will be all sorted with this bit being changed. At the same time, as the coolant has to be dropped to change this part, they're going to properly fix the coolant leak also from the pipe that joins the thermostat housing (I've given up, I think it all just needs taking apart, cleaning and putting back together again with a good quality jubilee clip).
Other than this it's doing sister well and flew through its 2nd MOT Thursday just gone
Old 22-03-2015   #25
Moderator
I'm not at all surprised by this - it's an incident waiting to happen.
Time to ressurect this post for those who haven't seen it.
I'd like to think it's saved a few 500's over the years.
"Just 'cos you're not paranoid, doesn't mean they're not out to get you"
jrkitching is offline Reply With Quote Quote
(T) Jacking the 500 (again) staffordmike 500 15 07-02-2021 22:58
(T) 500 jacking/ lifting/ axle stand positioning Andy Monty 500 41 08-11-2020 21:30
(T) Jacking-up the 500 FireballXL5man 500 10 07-04-2013 17:23
(G) Jacking punto MK2 with abarth side skirts beck_4ever Punto (Mk2/2b) 7 21-09-2006 15:12
