Old 11-11-2013   #46
72 Year Old teenager
chas379's Avatar
Trader Rating: 1
chas379 has donated!
Re: Fiat 500 Abarth for 2014? Possible changes / facelift?
Quote Originally Posted by ahmett View Post
I always floor my car so I am sure the DPF will be kept well clean = )
Ahmett, maybe you need a trip to the hospital to have the lead weights surgically removed from your right foot..
[SIGPIC]
chas379 is offline Reply With Quote Quote
Old 11-11-2013   #47
STOP! Hammer time!
306maxi's Avatar
306maxi has donated!
If I had to buy another Fiat 500 right now I would most likely get the Diesel (diesel in Greece is about 25% cheaper than petrol at the pump) and I always floor my car so I am sure the DPF will be kept well clean = )
It is a myth that putting your foot down will clear out the dpf, if anything it could have the opposite effect
306maxi is offline Reply With Quote Quote
Old 11-11-2013   #48
Speed Reader of the Year!
Most Easterly Pandas's Avatar
Trader Rating: 2
Most Easterly Pandas has donated!
Quote Originally Posted by 306maxi View Post
Agreed, will blow the heat right out the rear end.
Most Easterly Panda's - Panda'ing in East Anglia
Stockest of mk2 Panda Parts, PM for any parts requests
1993 Classic Panda Selecta, 1989 Panda 750L,
2015 Kia Soul EV, 2009 Qubo Dynamic Dualogic WAV & 2005 Panda Climbing 4x4 (LPG)
Most Easterly Pandas is offline Reply With Quote Quote
Old 11-11-2013   #49
STOP! Hammer time!
306maxi's Avatar
Not quite what i meant, excessive fuelling means more soot and fuel itself works as a coolant
Old 12-11-2013   #50
2015 Twinair 105
Mondaugen's Avatar
Mondaugen has donated!
Germany
Maxi, I’m mostly clueless, but while I guess this is correct for cars that have a carburetor, doesn’t the 500 have a fuel injection system that wouldn’t be fazed by operator stupidity?
Lambert
Mondaugen is offline Reply With Quote Quote
Old 24-11-2013   #51
Thanks for everybody's comments. We've decided on another peugeot. We're closing in on purchasing a 208 XY HDi EGC (Auto)
kkp0897 is offline Reply With Quote Quote
Old 25-11-2013   #52
UFI
500 TwinAir Plus
UFI's Avatar
UFI has donated!
Australia
Quote Originally Posted by Mondaugen View Post
99% of cars will got into fuel enrichment at full throttle. They purposely dump extra fuel into the engine when transitioning to WOT to prevent engine damage (keeping in mind factory tunes have to account for poor fuel, extreme heat, and unsympathetic drivers etc). You'll see all sorts of brand new performance exotica dump black smoke for this reason. More mundane machinery won't have as much enrichment so there's usually no visible smoke.
The TA does not do enrichment, so full throttle operation doesn't kill economy
UFI is offline Reply With Quote Quote
Old 25-11-2013   #53
stevehg has donated!
Quote Originally Posted by kkp0897 View Post
Seems a bizarre choice, boring diesel 208 with some shiny interior bits or a 500 Abarth??
Likes Most Easterly Pandas liked this post
stevehg is offline Reply With Quote Quote
Old 25-11-2013   #54
Trader Rating: 2
Quote Originally Posted by UFI View Post
I can't see this. If they do as you say there would be unburnt fuel entering the exhausts and CATs dieing left right and center surly?
Old 25-11-2013   #55
UFI
500 TwinAir Plus
UFI's Avatar
UFI has donated!
Australia
http://www.sdsefi.com/techtheo.htm
Quote Quote:
Oxygen sensor Under full throttle conditions, this sensor input is ignored by the computer so that the engine can produce more power by runner a richer mixture. This is called open loop mode and the computer is supplying the injector pulse width from tables based on all of the other sensor inputs. Once throttle opening and rpm are reduced to cruising conditions, most systems will jump back into the closed loop mode where they will stay for a large portion of the time on most street driven applications.
How else do you explain the flames out the back of my factory tuned Skyline?
(T) Facelift for Fiat 500 EU Stregax 500 6 08-06-2013 14:10
(G) Facelift Abarth 500 Sean_Bucks Abarth 500 12 09-04-2011 13:40
