Old 16-04-2013   #1
Poland
CV joint rubber cover leaking
I have probably first issue with A500. At the same day I picked her up from the dealer after covering about 120 km I spotted that there is some grease in the area of left CV joint (the one on the gearbox side). I thought that maybe in factory while mounting CV joints they left by accident some grease on the front suspension frame. So I cleaned it with paper towel and naphtha.
Since this time till today I covered about 1500 km. Today I looked once more in problematic area and again found grease exactly around CV joint (on gearbox, suspension frame etc.). It seems that the metal band on rubber cover is loose and when grease from CV joint is warm enough it goes out of it. Rubber cover itself seems to be OK - there are no cracks on it.
Tomorrow I am going for an engine oil change so I will have Abarth service investigate this problem. Below you will find some photos.
ID:	115722   Click image for larger version
Abarth 500 esseesse White Gara
Gregi is offline Reply With Quote Quote
Old 16-04-2013   #2
bgunn has donated!
Re: CV joint rubber cover leaking
Could also be overfilled with grease, which expands when hot and comes out.
bgunn is offline Reply With Quote Quote
Old 17-04-2013   #3
aka tony
grimwau's Avatar
grimwau will never be forgotten
grimwau has donated!
Hi Gregi, in the absense of a split in the gaiter, your diagnosis of a loose clip would seem to be the most logical answer. Although it is possible that the CV joint was overpacked with grease there is plenty of room for expansion inside the boot itself and if the clip was secure should contain the excess.
Let us know how it goes.
Fiat Abarth 595 Turismo MTA (the one on the right)
Picture taken at the 2013 New Forest Xmas Meet.
grimwau is offline Reply With Quote Quote
Old 17-04-2013   #4
bgunn has donated!
Quote Originally Posted by grimwau View Post
Depends how overpacked it is. I've seen numpties *fill* a CV gaiter with grease. You'd expect this not to happen in the factory, but if the grease dispensing machine was having a bad day..
Old 17-04-2013   #5
Trader Rating: 1
portland_bill has donated!
Make sure dealer removes boot and refills with correct amount of grease before fitting a new clip. If the grease quantity was correct, it is now not enough, just tightening or replacing the clip will lead to failure later, possibly when out of warranty. Make sure it is done right.
Excess grease is unlikely as this would waste money, so is likely to be very closely controlled at build.
13 years motor trade, 16 years motor industry. 16 years Driving Instructor & 9 years Fleet Trainer
Panda Alessi (2015 Skoda Fabia)
portland_bill is offline Reply With Quote Quote
Old 17-04-2013   #6
bgunn has donated!
Quote Originally Posted by portland_bill View Post
But you're not actually reading what I'm saying are you? What I'm saying is that it may have been overpacked due to a mistake.
Old 17-04-2013   #7
STOP! Hammer time!
306maxi's Avatar
306maxi has donated!
Fiat never make mistakes though. Oh wait, this is an abarth which is completely different
Thanks bgunn thanked for this post
306maxi is offline Reply With Quote Quote
Old 17-04-2013   #8
bgunn has donated!
Quote Originally Posted by 306maxi View Post
Should have bought a German car. They never go wrong.
Old 17-04-2013   #9
Trader Rating: 1
Quote Originally Posted by bgunn View Post
I appreciate what you say, but manufacturers control costs well. This grease will be dispensed by machine, carefully controlled. Could give insufficient grease if it ran out and the operator didn't notice, but unlikely. I suppose operator could double-dose it if distracted, but difficult to add just a little more, as it will be one-shot, or two-shots. This will be done at the driveshaft manufacturer, not by Fiat or Abarth.
Old 17-04-2013   #10
STOP! Hammer time!
306maxi's Avatar
Mistakes can and do happen everywhere
Old 17-04-2013   #11
sludgeguts has donated!
They don't really have much grease in them to begin with, all the boots I've done in the past have come as a kit - in the box you get boot, straps (cable ties, metal bands etc) and a sachet of grease. The sachet of grease never seemed enough to me, only barely half-filling the boot.
Sick of the constant tax hikes?
See how much it costs you & write to your MP.
http://www.petrolprices.com/itsyourduty/
sludgeguts is offline Reply With Quote Quote
Old 17-04-2013   #12
(edit's not working for me??)
OP. Just looking at your pics - for a car that's only covered 1500km, that driveshaft and track rod are looking a bit shabby, might want to slap something on to protect them?
Likes jrkitching liked this post
Old 17-04-2013   #13
STOP! Hammer time!
306maxi's Avatar
Quote Originally Posted by sludgeguts View Post
Meh, it's the underneath of a car, it rusts and matters very little.
Old 17-04-2013   #14
Moderator
It's well worth greasing the threads on the track rod; it will be much appreciated by whoever next adjusts your tracking .
Likes sludgeguts liked this post
"Just 'cos you're not paranoid, doesn't mean they're not out to get you"
jrkitching is offline Reply With Quote Quote
Old 17-04-2013   #15
Quote Originally Posted by jrkitching View Post
It may also ease the pain on your wallet next time you need the tracking adjusted.
If they can't crack the nut to adjust the tracking, they might spend ages trying (which will cost) or simply tell you it can't be done & that you need a new rod (because they tried & bent the rod!) - either way, a few penn'orth of grease might save many pounds down the line
(T) wishbone ball joint rubber cover info in here dave Punto (Mk2/2b) 14 27-08-2012 22:09
(G) cv joint rubber boot nightmare FROGMAN Cinquecento / Seicento 6 26-05-2012 21:08
Ducato CV Joint rubber boot Littlecot Tech Talk 3 21-03-2012 00:00
(G) Leaking CV Boot Joint PAULH Stilo 3 21-09-2009 12:50
(T) New Rubber Boots wanted for ball joint - help ChrisPa Cinquecento / Seicento 9 23-06-2005 09:45
