Hi Guys
I cant seem to choose any gears on my 900e, The stick moves the linkage moves all the way up to the gearbox but it does not seem to drop into any gears
On the gear linkage just before it meets the gearbox there is a lollipop type thing.
One end has two bolts and the other end has one bolt. On the end that only has one bolt if it comes undone by a couple of turns you won't transfer the twist action from the lever to the box to line up and select the gears. Make sure it is done up but don't over tighten it.
