The wheels & tyres on my 900T are long past redemption and I need to move up from 12" rims to allow for the disc brake upgrade.
Current set up is 4"x12" shod with 155/80SR12
PCD 4x98 - pretty standard for Fiat
Centre bore 58.1mm
I've been using the following websites in order to work out the size increase in order to keep the speedo accurate:
http://www.carbibles.com/tyre_bible_pg4.html
http://www.brick-yard.co.uk/forum/tyre-size-for-rim-width_topic60146.html
I'm down to two choices as follows:
5.5"x14" with 165/60R14
or
5.5"X13 with 165/70R13
Both options offer loads more tyre choices and often cheaper than having to get 12" tyres in.
Note: 5" wide wheels don't appear to be very popular, or only come in 13" rims.
All good so far but the final piece of the puzzle is finding out the offset for the 12" wheels. I've search through all the manuals I have, on the wheels and searched the web but the best I can come up with is a range between 30 to 40mm.
Does anyone out there know what the offset is for the 12" wheels?
Or has anyone swapped up to a 13" or 14" wheel and would be happy to share their choice of wheel & tyres?
Incidentally, I'm hoping to fit something like a late 1970's Wolfrace type wheel or similar unfussy style.
Centre bore 58.1mm
or
