Technical Rear seat belts
Hi Gary
I have a 1979 900t, recently had the plates welded in the back for seat belts.
we had a plate welded on both wheel arches and a single plate welded in just above the floor on the vertical panel below the cupboard, we had to remove the fibre glass cover plate first.
when the plates went in we tried fitting lap belts and found we had to buy longer ones, we do not have shoulder straps just lap only.
hope this helps
Tim
Gary
I've fitted 3 point seat belts to the rear of my 850T.
I've a different rear seat (r+r bed) in the back so might not be exactly the same.
I have a plate welded to the wheel arches, one behind the seats and one above the window. You do need quite long belts.
Andy
Hi Tim & Andy
Thanks for your responses.
If its not too much of a pain any chance that you could post a photo or two.
The van is completely stripped at the moment so I have plenty of options - just need to know where to put the extra metal.
