| Thread Tools |
![]() | #16 | ||
Posts: 192 Thanks: 6 Trader Rating: 0 ![]() | Re: Electronic Ignition Hi I opted for the Facet Position-Flow (bought from Merlin Motorsport: https://www.merlinmotorsport.co.uk/p...0104-fac-60104) There was no point buying the kit as the unions were a different size to the fuel lines I had - so bought them separately along with the glass in-line filter (also from Merlin).
![]() | #17 | ||
Posts: 192 Thanks: 6 Trader Rating: 0 ![]() | Re: Electronic Ignition Hi I opted for the Facet Position-Flow (bought from Merlin Motorsport: https://www.merlinmotorsport.co.uk/p...0104-fac-60104) Here's a pic of it in position. ![]() When I first fitted it it was slightly higher up, just below the filter (where the earth point is now). It would pull the fuel through to the filter but didn't have enough oomph to push it to the carb. This pic was taken this morning, I haven't started Connie for a week and you can see that the fuel filter is still full. I still need to put some heat shielding in front of the fuel lines etc. to help reduce vapour lock etc. (as the new 4-branch exhaust is much closer than the original single outlet).
![]() | #18 | ||
Posts: 4,946 Thanks: 233 Trader Rating: 0 ![]() | Re: Electronic Ignition Typo... 'Facet Position-Flow' should have read 'Facet Posi-Flow'. Here's a pic of it in position. ![]() When I first fitted it it was slightly higher up, just below the filter (where the earth point is now). It would pull the fuel through to the filter but didn't have enough oomph to push it to the carb. This pic was taken this morning, I haven't started Connie for a week and you can see that the fuel filter is still full. I still need to put some heat shielding in front of the fuel lines etc. to help reduce vapour lock etc. (as the new 4-branch exhaust is much closer than the original single outlet). ![]()
![]() | #19 | ||
Posts: 192 Thanks: 6 Trader Rating: 0 ![]() | Re: Electronic Ignition The fuel lines from the fuel tank to where they enter the engine bay (just behind the exhaust) follow the original path - you can just make them out in this photo. ![]() The fuel lines are the two pipes running across and around the bulkhead. The flexible hoses connect to the fuel pipes in the middle of the bulkhead and then connect to the top of the fuel tank (if you haven't already seen it the fuel tank sender and in/out fuel connections are one unit). As I've fitted an electric fuel pump, I've re-routed the feed fuel line across the back of the engine bay generally following the path of the return line. If you look at the earlier pic's of the 123-Ignition you can see these in the background. (When I add the heat shielding you won't see them.) If you are keeping the mechanical fuel pump the fuel line runs across the rear cross-member with a short piece of flexible hose connecting this to the pump. (This just adds to the list of bits to watch out for if/when you need to remove the cross-member i.e. to clean out the oil filter.)
Thread Tools | |
![]() | capristeve | X1/9 | 16 | 19-01-2012 11:45 |
![]() | Blurredman | Panda (Classic) | 3 | 30-08-2010 00:42 |
![]() | Alan.D | Panda (Classic) | 24 | 16-02-2010 23:13 |
![]() | shaun | X1/9 | 3 | 25-08-2008 20:01 |
![]() | bigfatbloke71 | X1/9 | 4 | 09-12-2007 15:06 |
