900 900t Restoration (Connie)
Hi
After having our 900T Amigo camper (Connie) for the last 14 years (off road for the last 10) we now have the time to work on the restoration.
Luckily for a 1978 Fiat she is surprisingly good condition, thanks largely to the Ziebart rustproofing.
Current status:
- Interior stripped, salvaged sink & cooker but rest was rotten.
- near side sill removed (practically fell off due to previous botched repair - pop-riveted on).
- Engine and gearbox out, largely out of necessity as rear wishbones had turned to paper. Local engineering firm laser cut the spring seats and rebuilt the damper mountings - now back on 4 wheels.
- Various panels sources many thanks to Ricambio.
Will be off to the welders in a couple of weeks to have all the welding done and generally made structurally sound (not much welding really).
Once back she will be stripped back to bare metal, rust-proofed and resprayed. Not sure what colour yet, probably stick to the original white.
I'll add some pic's to chart the progress soon.
I've posted a separate thread about how to upgrade the suicide brakes and would appreciate any suggestions.
Hi
No posts for a while been a bit busy.
Welding almost done, should be back home next week.
I must admit sending our Amigo to a professional welder was well worth the cost - I could never have achieved what they have done. Anyone around the Bournemouth & Poole area would have to go a long way to find some one as good as Trickett Welding. Not cheap but getting anything done properly never is.
I've just tried to include some images but I can only do that by including a link to them. I'm happy to do that but I've been blocked as I haven't made 5 posts yet :(
Fortunately, I've set up my own website to detail the restoration progress here: fiat900t.co.uk - as much for when I want to get an agreed value on the insurance as anything (and I build websites for a living so nice to have a bit of fun).
Fortunately the rust was held at bay by the Ziebart rustproofing so she wasn't in as bad shape as many I've seen.
The underside was generally pretty sound.
Water & petrol tanks removed to have a thorough check underneath and a few bits e.g. jacking points needed some TLC.
All now sealed ready for the tanks to go back in.
All in all there is probably more metal now than when she left the Fiat factory.
Just the guttering to do now, turned out that a previous repair (before we got her) had been pop-riveted aluminium. Horrible corrosion that just had to come out.
Next tasks...
Strip everything back to bare metal, rustproof and generally tidy up the lines with a bit of filler - nothing heavy just enough to give a smooth surface for the paint.
I'm no good at welding but this I can do.
Once prepped it's back to Trickett to take the top off, tidy up the offside gutter (where the roof attaches) and then resprayed.
Hopefully by October Connie will be back home and the reassembly will begin!
I'll post more in due course.
Gary, just had another look at your website.
Fantastic workmanship as you say.
I have much more than that to achieve but those reference photos have already solved several mysteries.
Many thanks, good luck for the rest am
And keep posting....please.
Still using your images for reference.(y)
The spare doors I had are being accepted back by the seller in PX as I placed a massive order for panels. So unfortunately I can't strip them for parts.
How's the restoration going?
Hi
Glad the photos are helping.
Connie came home a couple of weeks ago, I have a week's holiday at the end of September and I plan to strip the paint off. Back to bare metal then build up with fresh rust proofing and primer etc. I'm still deciding which way to go on this - there appears to be a few options and I'm busy reading the reviews on the Frost website
Probably a bit over the top but I want to make sure that there are no hidden problems that will surface in the near future.
The are a few minor dents to fill as well but nothing too problematic.
I'll keep posting photo's to my website and will drop a few on here as soon as I get past the usage limits.
Hi
As I can now post pictures on here I thought it about time I did :)
Here is Connie just before coming back from the welders:
The green paint is where she has been checked for 'holes', fortunately she wasn't in to bad a shape. I'll post the odd image here as and when but if anyone is interested the full diary of the restoration is here: http://www.fiat900t.co.uk
Next job is to strip the paint completely off (Hammerite over Fiat White - nice) down to bare metal and then build back up filling in the odd dent and smooth over the welding where needed.
I've ordered the POR 15 system from Frost including the paint stripper.
From the research I've done it appears to be the benchmark rustproofing system to use - I'll let you know how I get on with it.
I'm particularly interested to see how the POR paint stripper performs. If it delivers what it promises it should make the paint stripping a doddle.
Gary, I bought a competitor's POR 15-type paint and I was delighted how well it covered and set smooth and very hard. it was worth the expense and I used it in the wheelarches and all under the new floor of my Fiat 500. Over a year and a lot of miles later and it doesn't have any chips or areas that have peeled.
The key thing is prepare well, ie remove all loose stuff and make sure it's degreased and free of what they call "salts". Although it will go over any substrate it is better put on over rough surfaces.
The body & paint work has commenced.
Opted to use POR Strip as not as aggressive and as dusty as sanding. Once got the hang of it was very easy and takes the old paint off (including a top coat of hammerite) very easily.
Taking the paint off back to bare metal was the best choice in the end... just look at all the rust that was hidden under the paint!
More details on Connie's website here
Having just had the back of my legs whacked for the umpteenth time I'm taking a slight detour here.
The side door stay on Connie is little more than a wire coat hanger - see picture.
This is how she came when we bought her years ago but if we are to use her later I need to come up with a better method of holding the door open - especially as our 8 year old will be onboard (trips to casualty with trapped fingers are highly likely as the door is now).
Has any other 850T/900T/E owners got a better solution that they could include a photo of here? I have a couple of ideas myself but if someone already has a working (and safe) one I'd be more than happy to use it and give credit where its due.
Thanks in advance.
Rag top off.
Compared to many others Connie's 'pop-top' is barely wider than the van.
Roof accommodation is provided by two hammocks - big enough for a couple of youngsters but not adults.
More flexible sleeping arrangements could be in order!
Rag top off.
I think your resto is coming on great!! I have had my Pandora for two years now, and has been very much a running restoration as I vowed it wasn't getting laid up (the fate too many of my projects have met!). it is great fun to use tho and always turns heads. keep up your good work!
Gary, the top of my van is a different design...more sophisticated, if I may say so :). But where exactly did you start when removing it.? Did you have rooflining to take out.
I was just looking at the Blog and I envy the stage you have reached with the bodywork. Have you tried sanding that POR? I think it's going to be a struggle. I didn't realise you were using it on the body as I think it's usually used on the underside. It is good stuff though and I guess it will have the same long term benefits of the epoxy primer that I will be using.
Hi Peter
The pop-top on Connie is probably one of the simpler variants around.
Removal is straight forward, I've already removed the canvas (as you can see on the website). Starting from the bottom I drilled out all the pop-rivets holding the 'grip' strips in place first and made sure that the canvas was free from the body. Then simply unscrewed the fixings from the pop-up 'tub' - removing the ends first, then the section attached to the hinged side of the top and finally the outer edge. The only mildly tricky bit is holding the roof up will you unfasten the roof struts to feed the canvas through - my head was used as support for the 5 minutes it took :) (one end at a time).
The top is secured by three hinges and some serious pop-rivets. The removal of the top simply requires these drilling out and then lift the top off - a couple of tall people or a gantry would help here. NOTE: I'm leaving this job to the welders when she goes back to them in the New Year - the guttering needs welding up where the hinges attach.
The roof lining (looks like canvas pegboard) can be left in place - on Connie it appears to be glued in any case. You will need to take care when living the top off so you don't catch it and damage it through.
My canvas top has a few holes in it and leaks so I will be replacing it with modern 'canvas'. This will remove some of the bulk which will make it easier to pack away. While I'm at it I'm considering re-working the top to make more space for sleeping - but there are plenty more jobs to worry about before that.
Hope this helps
Gary
PS. I wish I had you welding skills - it would have saved me a fortune!
The instructions with the POR15 state that it's a pig to sand and I can agree with that.
The POR15 is self-leveling but you do need to be sparing when you paint it on to ensure that you don't get any runs - reading all the notes using a brush appears to be the best way. This is more down to the fact that if you spray it you have a high chance of wrecking your spray gun.
Two to three coats are required, I've only put one on the front so far. This will need to be sanded down/removed as the wind blew dust on to it while still tacky - not happy :(
Most likely I'll remove it completely and start again - the good news is that the POR stripper that I've been using to remove the old paint works well on the POR15 paint as well.
POR15 is generally thought of as for use underneath or in out of the way areas. However, it also has a sister product called 'self etching primer' designed specifically for use over the top of POR15.
The plan is:
- Remove all existing paint and underseal
- 2-3 coats of POR15
- Minor dents filled (filler goes on after the POR15)
- 1 coat POR self etching primer
- 2 coats of POR high build primer (sanding between coats)
- Final fine sand and prep for top coat
- Top coat
I wil be doing all of the above bar the top coat, this will be in a proper spray shop where there is no risk of dust blowing all over it.
By the way, final colour scheme will be:
- Green canvas (pop-top)
- White body with Italian stripe detailing
- Red vinyl (tuck & roll) interior with white piping and as much chrome as I can - think Italian ice-cream parlour
- Exterior bolt on bits (bumpers, wing mirrors, wheels, etc.) to be chrome
Can't wait!
Thanks for the comprehensive advice on the top removal. I could get away with leaving it as (touch wood) I don't have much guttering rust. But there is at least one broken hinge and a rusty bit below a gutter. There is a fibreglass pod moulded to the roof. The whole thing is like those roof lockers you can get for cars.
You seem to have the paint system sorted. I watch with interest.
It's been a while since any progress has been made on Connie and I've been an avid follower of Bluebell's progress so I thought it about time that I pressed on - one weeks holiday & good weather later here are the results.
In summary:
- Roof off (two man job - we could have done with being 6" taller)
- All paint removed from main shell
- POR Marine Cleaned (This strips skin as well - glove leaked, very nasty :()
- POR Prep & Ready
- Two coats of POR15
- All seams sealed with Eastwood Seam Sealer (this is like trying to force plasticine through a syringe. You need a strong grip but it's good stuff.)
- First coat of POR Tie Coat primer (this is a high build primer designed to be easy sanding - I hope it is as I've got a few runs (was getting cold and starting to get dark as I was painting)).
With the biggest single job done I can now crack on in small sections inside my garage.
Next on the list is to fill in a few dints and sand down the primer to a smooth finish, followed by a couple of more coats of primer and a final sanding ready for the top coat(s).
More photo's are on Connie's website: http://fiat900t.co.uk/?u=83&p=Body-and-Paint
Hopefully I'll be making more regular posts as I crack on with the restoration.
Major milestone reached... all primed, doors and panels back on and first two coats of gloss paint on.
6 days of work to get everything primed and painted - very sore fingers now :(
I'm really pleased with the result of the filling of the dents and weld joins - I know where they are and I can't find them.
Now need to wet sand all over and then two more gloss coats and two coats of lacquer to finish - wax in three months time when paint fully hardened.
The full log of what I've done on the paint work is here: http://www.fiat900t.co.uk/?u=83&p=Body-and-Paint
With a bit of luck the paint will be finished over the next couple of weekends and I can get on with putting everything back together.
Last 2 gloss coats, 2 coats of lacquer and wet sand and finish compound complete.
At this stage more of a lustre finish rather than high gloss but good enough for now.
As you can see from the photos the general rebuild has also started. I now know why most re-spary are done with the windows in... horrible job to put the windscreen back in.
