Old 26-11-2020   #1
USA
Abarth 500 - Boom after overcharged with offshelf gauged stopleak refrigerant can.
So it all started when I did a radiator flush. According to the instructions on radiator flush, I was to cleanout, refill and run this stuff with the heater on high. For a deeper clean it was suggested to run for a couple of days before refilling with fresh new coolant. So that's what I did ran it for about an hour with heater full blast, next day same thing. The third day when it was cold from not running it. Drained, flushed well with water to make sure all flushing fluid was gone, and filled up with Fiat antifreeze.
All was going well but I noticed the A/C was not cooling so well. Being in Miami Florida heaters rarely ever used, especially in high like I was running for radiator flush.
So who knows, maybe a leak or something developed. I started thinking, maybe the radiator flush had some acids that might have ate away something : O - ring? aluminum?
I stopped by the local autozone store and picked up some refrigerant charge, with stop leak and compressor conditioner. The can even had a pressure gauge, braided line and a quick release nozzle for the low pressure.
I drive back home, pop the hood, put A/C full blast, connect the can and it measures yellow for low. No problem , shake the can and start pushing through in like intervals. Gauge is moving up from yellow slowly towards the green. All of a sudden , it by passes green all together and goes right on the beginning of red line. I immediately disengaged and figured some will probably leak out a little. I will be good.
Go in the house, hour later get in the car. A/C is blowing nice and cold. Then I start hearing like this jet noise, and then a BOOM. I even felt it in the cabin, but can't remember if it was the startle of the noise or a something exploded around the center firewall. What ever it was it was not good.
Looked around every where and no signs of oil residue. Compressor stopped working.
Bought some more refrigerant with stopleak. tried a little this time. Compressor would kick on as was filling system then shortly after stopped. Looked like leak somewhere in engine compartment area. Low pressure hose look like a culprit. Changed it.
Compressor then wasn't working and left it alone when all the Covid stuff started. I been fidling with it, ended up getting really gauges, a vacuum pump. and still will not hold vacuum and compressor will not engage. tried pushing florescent dye through system with compressor not working engaged but no signs anywhere. I even went a little courageously crazy and took the whole dash iut and looking in through evap / heater box for fluorescent traces and haven't really seen anything. Anyone have any clues, ideas, suggestions?
ormani is offline Reply With Quote Quote
Old 26-11-2020   #2
It's always more involved
John202020's Avatar
John202020 has donated!
Re: Abarth 500 - Boom after overcharged with offshelf gauged stopleak refrigerant can
Take it to a professional, this is a perfect example of why you should never try to fill a a.c. system yourself, no disrespect.
John202020 is online now Reply With Quote Quote
Old 26-11-2020   #3
Moderator
Hi and welcome to the forum.
Sorry to hear about your problem.
Quote Originally Posted by John202020 View Post
Take it to a professional, this is a perfect example of why you should never try to fill an a.c. system yourself, no disrespect.
Quote Originally Posted by ormani View Post
These types of products are generally little more than snake oil and often do much more harm than good.
If any kind of HVAC system is leaking, you need to find out why and fix the root cause of the problem; not try and seal it with an additive.
But what's done is done; the best thing you can do now is to take it to a specialist A/C shop and see what they advise.
Likes Baglady1990, Pugglt Auld Jock liked this post
"Just 'cos you're not paranoid, doesn't mean they're not out to get you"
jrkitching is online now Reply With Quote Quote
Old 26-11-2020   #4
chris3234 has donated!
You probably overcharged the system or the stopleak stuff blocked something up causing the pressure to build up until it blew something apart
Possibly the evaporator in the cabin airbox
Definitely take it to a AC specialist allthrough the bill may not be cheep now
Likes Baglady1990 liked this post
chris3234 is online now Reply With Quote Quote
Old 26-11-2020   #5
USA
Im past that point now since I have already taken apart the dash and am going after the evaporator.
Since I heard the jet noise , stuff coming out of vent like a cloudy air before I heard the BOOM.
I should be at the evaporator today or tomorrow, just need to figure out how to remove the raw steel tube brace that holds dash up and eveporator housing in place. Looks like the bolts are coming from outside car and doors are going to need to be removed.
ID:	214158   Click image for larger version
Old 26-11-2020   #6
Moderator
Yes, to properly access the heater box both doors have to be removed to get that steel brace out. The heater box is just about the first thing to go into the bodyshell when the car is built.
There's a workshop manual for the European cars which you can download for free from the downloads section of this forum. How much of it is compatible with the North American market models I don't know, but you may find something useful in there. The procedure for accessing the evaporator matrix is described in some detail.
As you've already found out, it's a lot of work. Good luck, and do keep posting how you're getting on.
Likes Ralf S., The Panda Nut liked this post
Old 26-11-2020   #7
John202020's Avatar
Yep I suspect the evaporator has exploded.
30 years of Honda Accords, now Mazda 6 and a Fiat 500
Old 27-11-2020   #8
USA
Went to take out doors to get bolts from frame out but was able to get bolts to clear enough to free steal cross frame. On the left door I unbolted door stay and freed rubber tube that wires pass in through door. Learned from right door none of this is necessary.
The door stay allen bolt can just be loosened out like 1/4 of an inch, and the 15mm bolts on door like about 3/4 of an inch for top, bottom 15mm door bolt maybe just half inch out. Door will just sag enough to clear.
I also grabbed a magic marker and marked were the hinge was sitting just incase of alignment later. do this first before loosing anything obviously. I worked the door bolts a little, then the cage frame bolts then back forth. Did this so I could losen the door bolts just enough to make the clearance.
would have sucked if the door bolt came off. would have sucked trying to put back in with heavy door, not to mention a wire pulled.
It turned out to be less invasive, just slowly wrenching the 13mm bolts little by little with the wrench did take some time and patience. It's quarter turns for a while till can do rest by hand. didn't want to try and use socket from outside through door gap.
That's all I need is a crease in the door cause it moved. It's like this is all a lesson for mindless shortcuts. If I just would have put an ounce less of refigerant stopleak maybe this wouldn't have turned into such a nightmare.
ID:	214161   Click image for larger version
ID:	214163   Click image for larger version
Likes Pugglt Auld Jock, Gina500 liked this post
Old 27-11-2020   #9
USA
Wanted to attach this photo. Didn't know how to go back and add by editing.
Likes Gina500 liked this post
Old 27-11-2020   #10
Moderator
This is one of the reasons why the workshop procedure recommended by Fiat is to remove the doors completely.
If anyone tried doing what you have done in a busy workshop, the car would likely be a wreck by the time the job was finished.
Likes The Panda Nut liked this post
Old 01-12-2020   #11
Germany
Great work so far, now we hope you get to solve the problem.
Likes Ralf S., jrkitching liked this post
Cheers Mike
500C Spiaggina '58 with leather interior & flower vase
Gina500 is offline Reply With Quote Quote
Old 02-12-2020   #12
USA
Well finally got the evaporator / heater core. It's is 100% confirmed that you do not have to take the doors out, if you want to patiently use an open end wrench to loosen the bolts the whole way. Trying to squeeze a rachet between door and fender to save time is not advised.
what is aso a plus of not removing the whole way is if you are doing by yourself if you had to hold the door and alighn the holes might be challenging. I saw a post were a person replacing their complete door was using a car jack. I have also been able to open all the way to get in and out if necessary with no problem.
I had used usome UV dye a couple of months ago wondering if these are traces under the black light.
marching forward. next will get new evaporator core, new expansion valve, new seals just to make sure.
hope that's it and start putting it back together, patiently, slowly, and cautiously.
good thing is the clips go on a lot easier than it is to take them off, and that seems like tge whole car.
It was designed for the assembly line.
ID:	214278   Click image for larger version
Likes Gina500, jrkitching liked this post
Old 02-12-2020   #13
Well.. we've all been there... it's called a "learning experience"...
I think "doors off" is just the easiest/quickest way if you have assistance available but it's useful to know that it can also be done with the doors still on if you're on your own (as we usually are).
Just test that the a/c works before you put the dashboard back together... and also test it again between the dashboard being re-installed and the doors going on. It'll be a bummer if you get to the end and some plug or something inaccessible isn't connected..
If you have Climate Controlled a/c rather than a manual dial, check that the flap actuators are working, before you put it all back. It could be that the radiator flush gave the heater a workout and it's now flowing more hot coolant than before, which may have led to the a/c feeling warmer if the flaps are jammed (quite a regular problem).
Otherwise, the cooling system is not directly connected to the a/c so don't blame yourself for flushing the coolant. Any damage in one system doesn't affect the other (apart from they work together, obviously).
You did clumsy-break the a/c though.... but, you're fixing it despite it being a bit of a mission... so you shouldn't beat yourself up about that.
Ralf S.
Likes ormani, jrkitching liked this post
No bullets for chaingun
Ralf S. is offline Reply With Quote Quote
Old 02-12-2020   #14
I'd make sure you get the system does professional this time rather then using the top up kits
As it's been open to the elements it really needs to the air and moisture vaccuming out of the system to ensure a good life span
Good repair job however
Likes ormani, Ralf S. liked this post
Old 02-12-2020   #15
Yes.. takes a few minutes, doesn't cost soooooo much more than the aerosol cannisters, if you hunt around for a promotion especially... and if they blow it up, you'll at least be able to re-assure them that all the nuts and bolts will come off easily, since they were done not long ago..
Ralf S.
(T) Refrigerant Type Pieter1234 Fiorino (Mk3) 4 12-09-2017 21:00
(G) Boom Boom Boom goes my 500 XIIX 500 9 11-02-2008 17:59
(G) custard mobile gets a bit of boom boom custard Cinquecento / Seicento 10 11-05-2005 11:16
(T) heater matrix - stopleak thinker Punto (Mk2/2b) 6 10-04-2004 23:20
