I am having trouble installing the right engine mount after timing belt replacement. I removed the transmission mount put a wood block under the oil pan and used a hydraulic jack to slowly lift the right side of the engine upward but it will not go far enough to slide in the mount. What might I be doing wrong? Any suggestions? It's so very close to going in but not......
