Old 10-08-2014   #1
USA
2012 USA Fiat 500 POP, rear brake pad replacement
I'm having difficulty moving the new pads far enough apart to fit over the new rotor on the rear brakes. I believe the problem is with what I believe is a parking brake adjustment, but I'm not seeing how to adjust it for sufficient clearance. I have a clutch adjusting tool for an old SAAB which will turn the Maltese Cross looking parkinging brake adjustment (which is also the caliper piston, I believe) and I just can't get the opening big enough. Lacks about 1/8 inch clearance. These calipers say TRW. I should note that I have completely removed one of the calipers from the car and used a large "C" clamp on the caliper to attempt to squeeze the piston back into the caliper. It won't move, apparently it is already as far back in the caliper as it will go.
Last edited by Greatguns; 10-08-2014 at 01:19. Reason: Add something I forgot to mention.
Greatguns is offline Reply With Quote Quote
(T) Price for rear brake pad replacement. SubJectioN Stilo 4 07-06-2012 10:42
(G) Sticky for rear brake pad replacement trumpeter Stilo 5 03-02-2009 20:33
How much? Rear Brake Pad replacement 1.2LStilo Garages 5 28-12-2007 09:47
