Minimalist
I'd like to know if anyone has driven both an automatic and manual Fiat 500. I test drove a Pop and Sport, both automatics. I didn't quite understand the Sport mode at the time. I think I was in normal mode most of the time.
Acceleration was alright. Not brisk from a stop. On the freeway I used the manual slide shifter thing(Auto Stick driver-interactive manual control) on the automatic. At one point I was able to go from fast, maybe 55mph, to faster quickly when I dropped it to 4th gear. It was my last available moment to do that and I finally was able to see some brisk performance from the vehicle. I wanted to see if the vehicle can do this for practical situations like going into a faster lane and needing to keep up and entering a freeway from a stop at a meter light.
I should have done the test drives in a less busy hour. It was the middle of the day in Costa Mesa, California.
So anyways, I haven't driven a manual stick shift car before. Just a manual shift motorcycle. A friend will teach me how on her manual car.
But for now, has anyone compared the manual Fiat 500 to using the Auto Stick driver-interactive manual control in the automatic Fiat 500? Does going manual in the automatic compare to the true manual Fiat 500?
I see six different things to compare, if I have this correct:
1. Automatic Fiat 500 normal mode D gear(automatic drive)
2. Automatic Fiat 500 normal mode driver-interactive manual control
3. Automatic Fiat 500 SPORT mode D gear (automatic drive)
4. Automatic Fiat 500 SPORT mode driver-interactive manual control
5. Manual Fiat 500 normal mode
6. Manual Fiat 500 SPORT mode
I assume using the driver-interactive manual control in an Automatic Fiat 500 in SPORT mode is different than normal mode. Or is it not? I assume 4 ways to drive the Automatic Fiat 500. Or if SPORT mode can't be used with the driver-interactive manual control, then 3 way(D gear normal, D gear SPORT, manual control).
I do know the true manual Fiat 500 has normal and SPORT mode that adjusts shifting/performance.
Anyways, I don't want to repeat things here. I wanted to know if Automatic manual control compares to true Manual in the Fiat 500. In terms of shift gears and getting performance out of the vehicle. Or is the true Manual Fiat 500 still a better performer than the Automatic?
And finally, has anyone done number 3, Automatic D gear in Sport mode? I'll have to test drive trying this again to see if that helps in going from a stop.
Sorry if this post drags on. I'm trying to decide if the Automatic will be just as good or comparable by practical means to the Manual, or if I'm better off with the Manual.
