FIAT Auto Specialist Team
Comment
Guide Tools Search this Guide
Broken Door Handle Articulator (hinge) Repair
MarcoVenturi
07-01-2013
<a href="https://www.fiatforum.com/attachment.php?s=37178e422d159352765fb04c1cf39088& amp;attachmentid=111241" target="_blank" title="Name:
Size: ">Attachment 111241</a><br />
<br />
Just follow the
Old 4 Weeks Ago   #45
Re: Broken Door Handle Articulator (hinge) Repair
Morning all! Have an issue with the door handle (see image). At first I was thinking of trying to stick with superglue But would you simply recommend I change the door handle? Door opens without issues for now !
gaurav500 is offline Reply With Quote Quote
Old 2 Weeks Ago   #46
Canada
Just replaced mine but now the latch stays open when i pull it, still prefer that than having to pay what the garage was charging to fix it, any one else have this issue? did i mess up the spring??
supfi is offline Reply With Quote Quote
Old 2 Weeks Ago   #47
varesecrazy has donated!
Quote Originally Posted by supfi View Post
What did you replace.. whole assembly..or just some parts?
Old 2 Weeks Ago   #48
Canada
just the articulated hinge inside the handle ,, the piece on the right in gaurav500 s photo , theres a little hinge inside that snaps, i saw a spring on the other side ( inside the door) but dont remember any tutorials mentionning anything about it. i did have a problem with the rear wiper spring... ( maybe they make bad springs?)
Old 1 Day Ago   #49
Thanks for the pdf and tips, managed to fix it this afternoon! Some tips from me:
1. Get yourself some plastic trim removal tools, inexpensive and help a lot!
2. Use a small mirror, helped me to locate where the screw on the hinge goes and then locate where the door card plugs need to go back
3. For the hinge screw I tightened by hand with a PZ screw bit, but then fully tightened from the ‘inside’.
4. Be patient! Disassembly was a doddle but putting it back, especially the hinge itself and the door card was a pain with a lot of swearing involved! If you can ask someone to help it would make it easier.
Comment
Search this Guide:
(T) broken door hinge wongkey Multipla 1 22-04-2011 01:47
(T) Broken interior door handle jackson74 Stilo 2 19-08-2010 17:32
(G) Sticky / broken door handle james_f Panda 3 19-07-2010 23:12
(G) Sticky / broken door handle james_f Panda 5 12-05-2010 20:53
(T) Broken door handle BrunieP Cinquecento / Seicento 3 04-04-2005 20:02
