For a small carb they do suffer from more than their fair share of problems and you seem to have had a number of them. Spindle wear is one of the worst problems especially as it is the carb body wears the most. I have rebushed a few carbs to overcome this making and pressing in a small duralumin bush. Bottom mounting flange bending is very common but can be sorted but it is important to use good gaskets and that the Bakelite spacer is in good condition. Probably the worst thing is the secondary venturi working loose and wearing away itself and the carb main body. Brass floats can develop hairline cracks, brass inlet ferrules can fall out, inlet valves can wear and stick, top covers warp, stripped threads is so common and so on and so forth.
