...is this how you mounted it? I know their instructions say to mount it on the coil, but a previous thread highlighted some issues with that, and from what I can gather, this is correct. I'm getting this distributor setup for some further troubleshooting.
After my air dam experiment, there's still a miss @ about 85-90km/h. Better than before, but still present. I can't seem to duplicate it at similar revs at lower speeds, so I'm wondering if there's an airflow issue at speed. It only happens above ~80 km/h and once it starts, if you stay in it, it'll get progressively worse. Once you ease off and get on back roads at varied speeds/revs, all is well again. Tappets are spot on - adjusted before the test run and check afterwards.
It was doing this before on the old motor as well. Carb is completely different now and only the fuel pump remains the same. I'm a little lost here. Ideas?
