- Mar 1, 2021
- 76
- 20
Hello all my name is Stefan Aka Navo I'm currently in the process of building my first fiat engine, I'm using the 126 650cc engine for my 1972 500.
I'm undergoing the process of adding a oil cooler to it but instead of using a generic kit I'm welding a take off on to the oil pump housing.
What I need is a little confirmation as I've seen All sorts of opinions.
I've been told that I need to add a restriction to the driven pump gear with a 2.5mm hole in it.
What is would like to know is, is this correct info? Does it affect the lubrication of the engine by changing its original path?
Please bare with me as I'm turning to the knowledge of the community so I can build this car properly.
Many thanks in advance
