Hi all - been working on a disc brake conversion on my 1971 500L. I bought a kit that’s admittedly over the top for the car, but seems very good quality. Anyway, I have the new calipers and wheel hubs bolted on and all set. No wheel clearance issues except that the tie rod ends (ball joints) and their rubber boots just lightly contact the brake rotors (discs) on both sides. It’s not enough to impede the rotors from turning, but definitely a problem because the spinning discs will cut the ball joint boots and probably occasionally contact the discs metal to metal. I have to increase the clearance.
Below are a couple of photos. It looks like the ball joint is severely cocked but even when the car is set down off the lift and the tie rod angle relaxes a bit, it’s still too close.
The tie rods are relatively new - they FRAP. They are pretty robust, but clearly fit prior to the new disc brakes and had no issues with clearance from the old brake drums. I recall the original factory tie rods and ball joint heads being much smaller, but unfortunately I binned them after I replaced them. But my recollection of the originals makes me think the brake kit designer had them in mind when he designed the kit. I think they were small enough to provide clearance.
Wondering if anyone has any ideas. Thanks!
