PointFiveO
Member
- Mar 24, 2012
- 71
- 70
Hi All, after dealing with running issues while the engine is hot, which, after a process of elimination seem to point to the existing 123 electronic ignition having gone bad, I am considering replacing the electronic ignition. I'd like to replace it with the same 123 ignition. My car has the 123 ignition Plus which came as a unit with the distributer part attached. I know it's also available as the ignition unit only for use with the old type distributer body. I see from a quick search that this later ignition only unit seems to be what is generally available now. Am I right to assume that the 'faulty' ignition part of my 123 Plus unit can be detached and simply replaced with the new ignition unit reusing the exiting distributer part or is it possible that I might have to also buy a new old style distributer to strip and convert for use with the ignition?
