Hi all, new to the site, and new to Fiat 500s as well, but we took the plunge and bought this 1972 car A couple of months ago as a little runaround for nice days. The picture was on the first day we got it home - there’s nothing wrong with the handbrake, but it’s a sloping drive and I’d rather be safe than sorry until I knew it worked properly!!
All good so far, until this week. After about 20 minutes of driving, got a small misfire under load, which then got very quickly worse to the point where the car would idle, but cut out as soon as you touch the throttle. I called out the RAC, As had no tools or anything with me. They checked fuel, which flowed fine, checked the carb for blockage and cleaned it out, and checked for spark. There was a spark, but still no joy getting it to run - by now it wouldn’t even idle, just fire on the starter. He tried adjusting the ignition timing (turning the distributor), who seemed to make it marginally better, but it still won’t run.
The car has a flat distributor cap with one wire coming out, to a coil unit with 2 HT leads (wasted spark?), but I’m stumped on what to do next. My thoughts were try and find TDC So at least I know it’s timed about correctly, but there don’t seem to be any marks to time the distributor against. After that, I guess I need to check each component is working, but not really sure how. Can anyone help?
