Hello all
the question of kingpins once again raises its ugly head.
I have read with interest the sticky on the site and was about to this job with a friend using a pair of assemblies obtained from a mechanic in Italy. I was hoping to remove the existing assemblies and re-fit the replacements directly.
However before doing so I would appreciate some advice as to distinguishing whether those replacement kingpins are indeed adequate for the job without further work or whether I need to have the bushes etc, changed for them anyway. In other words, is it possible to determine when off the car, whether a kingpin assembly has good play within tolerance rather than excessive play. I have a feeling that the answer is going to be that the leverage exerted on the stub axle is not possible to replicate in practical terms at home.
The replacement kingpins do appear to be packed with heavy grease and are very stiff to turn by hand.
Thanks in advance.
RDS
Thanks in advance.
RDS
