the hobbler
Distinguished member
- Jul 25, 2012
- 4,045
- 1,005
Pertinent words of wisdom and advice Al. One of the reasons that I use "Westfield fasteners" for most of my nut and bolt requirements is that they list the relevant specifications of all the bolts that they supply. For example:--- a high tensile steel 8mm screw (full length thread) can be to:--ISO 4017 (DIN 933) in BZP (bright zinc plated), class 10 (10.9). Just for information they will supply a pack containing 10 of 8mm x 25mm to the above specifications for £3.15p + VAT.
Al is correct in pointing out that 'stainless' should NOT be used in any stress applications; I only use them for stress-less appearance reasons (holding the fan-shroud parts together/on etc.) Westfield can supply just about all the stainless/high-tensile bolts one would require, including plain and nylok nuts. They can even supply '1/2' nuts, both plain and nylok, for the occasion that a shallower nut is required----all at very sensible prices with first-class service. And that is the reason that I use the Company and recommend them.
