El cargador
Member
Hello All, can anyone help with rich running on my 500. It is a 26 imb10 and is not the original carb but the jets are correct according to the haynes manual(112 +0.45) ive checked the valve clearances but not the timing yet as its fitted with an electronic system in the carb and at the moment i am without a timing gun. Also float adjustment.
If i understand correctly if the incoming fuel is set by the jet size and cannot be altered then i presume the air flow could be restricted, I took out the air filter and went for a run . I took out a plug on return and it seemed to be better but after another run it was back to black again. Please helpppppppppp
