I have recently bought a 1972 500L with 652cc engine, oil cooler & Weber 40, road race head oil cooler underneath back seat ( obviously outside) with disc brakes all round with a very highly tuned engine
My question related to the fuel pump, at the moment the car is using the standard mechanical pump, however this is making it very hard to start from cold, I assume it's due to the fact it only feeds the carb when the engine is turning over and as it has a Weber 40 this takes about 10 to 15 sec to fire up.
Am I correct in assuming fitting a push pump next to the tank will speed up the starting?
I also have noticed there is a spare copper fuel pipe blanked off at the top of the engine compartment the other end seems to go back to the fuel tank somewhere. Should this be connected to anything or is it some sort of breather pipe.
